TaTundra 1 gen DC build
I'm debating going to 255's right now. I have 265/75/16's on now and like it but I have always liked taller narrower tires
BTW, THANK YOU for the heads up on the LED light kit. Amazing difference those make
Glad it worked for ya, compared to a 265 the 255 will be much taller but almost the identical width, they actually were wider than I was expecting, but I have them on a really narrow 6.5" rim so they stand up quite nicely
So finally got around to swapping out my tapped out tired coil springs. I never liked how much preload you need once you put some armor on the front of these trucks with a DC. So the original coils are 14"700# springs. They're 4 years old and pretty beat up. Talked to the techs at swayaway and they emailed me a worksheet where I filled in measurements and they told me I can run a 16" 700# spring. This would allow me to run with the adjustor ring all the way at the top and hopefully get a smoother ride. Also got some wraps to cut down on the rock chips and paint damage, we'll see how long they last.
Terrifying!!
Better!
While I had the coils out I figured I'd see how the 255's stuff, this is on the bumps, so the way the DC front fenders are you can see without serious trimming this about maxes out the tire size pretty darn tight
Full droop
And got a new toy, 1100ftlb torque figure could come in handy on the trails
Ya turned lock to lock and only had slight touching on mud flaps and fender liner, nothing major, I still run a sway bar so really the only way I'm gonna hit the bumps is in a straight line... Most likely at a high rate of speed
Ya ordered them right from poly performance, they have different length ones and they have heady duty Velcro
You are a brave man compressing 700lb coils with that type of spring compressor! Nice work getting it done safely!
The main spring compressors that are in the pic are heavy duty ones and are ok to use on these springs, the dinky 3rd one there was just to keep everything aligned but yes terrifying anytime those springs are that tight
So got sick of the naked back end look, added an actual mounting pad for the license plate and filled in the rear holes to clean up the look, it was a bigger job than I expected getting the angles right. I decided to put the plates at the back so it still has the tube look just not looking down the frame rails, tapped and sleeved holes through for the plate so I could add some led plate bolts, I think it turned out pretty good...
How much did you have to compress the 16" coils to fit your coilover? 1.75"-2"?
Do you mind posting your message exchange with the guy at SAW?
I know it's long but hope it helps someone else, if I would have known this at first I would have never even bothered with 14" coils
Compressing them want very fun but in the end gained space between each loop of the coils and as you'll read these are the coil he recommended, again the "bounce" over small bumps was reduced due to less preload
Me:
Hi, I have a 2005 tundra double cab with an Arb front bumper and. with sway away 2.5" coilovers with 14" 700# springs. Right right now I am sitting at about 2" lift and the coils have 1.75 " of preload which leaves them quite compressed at ride height. I am adding a winch to the front and am worried about sagging in the front. Will it work to put a 16" 700# coil on there to try and use the full adjustment of the shock or
Do you have a recommendation for what I can do to remedy this. I don't want to crank it anymore and would rather have the coil fill the entire shock, hopefully you can help me,
Tyler
Eric:
With that spring and preload combination you're at the block height of the spring at full bump so you can't add anymore preload. If you went to a 16-700 you would have to back off the adjuster nut to only .687" of preload because the block height is longer. So with gaining 2" in free length and loosing 1.063 in preload you get 0.937" of lift at the shock. I don't know what this translates to at the wheel without the dimensions from your lower arm. Look at the picture I attached as tell me what D2 and D1 are on your lower arm and then how much weight will be added by putting the winch on. I will be able to tell you how much it will affect the ride height with your current springs and you can decide whether or not to leave them the same or change springs.
Eric Tice
Me:
Excellent, I took some more accurate measurements:
Preload: 1.625"
D1: 8"
D2: 19"
I would like to keep a similar ride height to what I have and the main thing is I want to have as little preload down the coilover as possible as I find on small bumps the front suspension is quite jarring. The winch that I am adding is 112lbs And currently have 220lbs nitrogen in the shocks. Let me know what length and spring rate you would recommend, I added a picture of what I'm looking at too, coilovers are 4 years old.
Eric:
With making some rough assumptions in the math for the sake of simplicity and time, adding the winch will only drop it about 1/4" at the tire centerline. Its only a small amount because the spring rate is so high. Whether or not that drop is too much for you I would only recommend going to the longer spring. 700 lb/in is already stiff as hell and the highest rate Eibach advertises on their site is 650 so I'd assume you're in custom territory with your 700 or anything stiffer. 16-700 is a standard spring they list on their site. So with the longer spring and the winch; if you back the adjuster nut all the way out so its against the top cap you'll get 7/8" of lift at the wheel centerline. Thats the minimum lift that you can have with that spring. On the opposite end of the spectrum you can crank the nut down to 0.687" of preload and get 2.5" at the wheel centerline. I don't know what lift height window you're looking to stay within, but in my opinion the 7/8" would most likely be reasonable from a geometry point of view. Anything more than 1.5" or 2" and you would be stealing from droop travel. Let me know if you have any other questions.
Eric Tice
Hello Tyler,
Our engineer, Eric Tice, informed me that you are interested in purchasing heavier coil springs for your coil over shocks, part number 16-700-3
At the present time, we do not have these coils in stock.
Please refer to one of our dealer's website to purchase these.
http://www.polyperformance.com/shop/Eibach-16-Long-3.0-ID-Coil-Springs-p-11
Interesting.
OEM coil spring rates are:
575 lbs: 2000-2006 Stock Access Cab Coil (This is the actual spring rate)
750 lbs: Double Cab Coils. (What I read on TS from people that said they verified this from people that work for Toyota and verified this in the Toyota Parts Dept.)
Interesting.
That is very good info. Surprised that the DC is that much heavier. Maybe I should try a set of DC coils with my 5100 and see how I like it
LukeSkywalker515
