Very nice. I miss my old GDub.
Get to know the fellas over at IFSJA.org, they know all the tricks for these.
I'd recommend that the first thing you do is dump the t-case oil and see what condition it is in. if the fluid looks greasy or silvery than the viscous coupler is blown out. Don't bother rebuilding the case, try to find either a 228 (same part time/full time, just no VC) or a 208 (true part time case). The disadvantage of the 228 v the 229 is that in 4H, if you lift a single wheel, all the power goes there. In 4L the front and rear drives get equal split like any other "normal" case. I had a 208 in my Waggy. The 229 was in great shape, but I wanted a true 2H,4H,N,4L case.
Dave
What trucks did the 208 come in?
BTW, I noticed that yours has an aftermarket receiver hitch. If there is not a transmission cooler in front of the A/C condenser, than yours probably didn't come with the factory tow package and will likely have 2.72 gears. Don't attempt over a 30 inch tire without a gear swap. I put 3.73s in mine, planning to move to 32s or 33s, but stayed with the 31s because I really liked the power off the line. The tow package got you 3.31s.
Dave
