The B*tchin Defender gets a playmate
dieselcruiserhead
16 Years on ExPo. Whoa!!
congrats -- $5G is a score even with the head work. Killer! A friend has a '91 LWB on OME with some protection that I have just grown to love, very neat truck.... His only gets abourt 13mpg too :sombrero:
gjackson
FRGS
Yeah. The engine is worth $5G. The rest is just icing!!
Hold on Graham, the line at Keith's door for 24 spline conversion starts behind me. No cutting
:) But I can drive to Keith's place in 20 minutes. :shakin: Which means I can bribe him with :beer: .
cheers
gjackson
FRGS
Damn! You got me...
I'll be nice. I don't like line jumpers.
I'm partially satiated by the fact you had to go diesel to get over your 60 envy.
Yeah, the diesel is working for the most part. But that 60 you got is awfully awesome. Just think, if we put my oil burner in your 60 we'll be able to compete with Roseann. :Wow1:
cheers
gjackson
FRGS
So there is a long and involved story behind this update, but suffice to say the RR is currently in the garage sans-head. Due to some strange and as-yet confounding cause, the new head I put on the RR also got warped. There was some heat involved.
So back on the market for another solution (and not an expensive one) I tried to convince a machine shop to surface the warped head. Most Land Rover people will tell you it cannot be done. Including Land Rover. The guy at the shop I took it to eventually decided they were right, but he did fail to try. So I delivered it back to Jim as he though he might be able to convince his shop to do it.
Enter the financial crisis and the amazing fall of the British pound. Over the course of a week a new head from the UK went from unobtanium (quickly) to a real prospect, to a much better deal than I could get anywhere in the States. Including from Rovers Down South, and that's saying something. Actually it was George who told me to get in touch with Turner (http://turner-engineering.co.uk/). After a brief conversation I had a performance head (+ 8 to 10hp over stock) on its way for 20% less than a head from Rovers North with no shipping.
There was some fun getting it here, but now it sits waiting for me to get time to put it in. On it's way it went to SEMA to check out the Land Rover offerings there and to help Scott with the Disco. It got a very nice overland tour with Nathan and it finally arrived at my house ready to go on the RR. And it's so pretty!
cheers
ntsqd
Heretic Car Camper
So what is/are the heat issues that appear to have repeatedly warped cylinder heads?
gjackson
FRGS
The engine seems to have a pretty random overheating issue. Sometimes it won't overheat, then suddenly it will. So I'm going through everything as I put it together to try to find the cause.
I'll post up when I do!
cheers
Hltoppr
El Gringo Spectacular!
Graham,
I just recently spoke with a chap who put a GM 6.2 diesel in a 130 Crew Cab, and was having overheating issues. Turns out a heater hose was catching an air bubble, causing some issues with circulating coolant....
Since it's a conversion rig....might add that to a list of possibilities...
-H-
gjackson
FRGS
Andrew,
That is certainly on the list! Thermostat, fan clutch, all hoses, injection pump timing, head gasket thickness, watersystem leaks, flow blockages, water pump, radiator, heater core etc.
All things to be looked at. I'm going to spend a lot of time in the garage with the engine running making sure the system is fully bled.
Thanks for the suggestion. Do you have pics of the 130? :D
cheers
Alaska Mike
ExPo Moderator/Eye Candy
Might check the height of the radiator as well. The cap should be the highest point in the cooling system, to allow for correct pressurization and flow. If you don't already have one, an oil coiler might help reduce the problem as well, and give you greater oil capacity.
What thermostat rating are you using? do the main hoses deform at all (collapse)?
Good luck- it can be extremely frustrating to sort these things out sometimes.
Michael Slade
Untitled
There's a silver lining that I'm glad you found. Have you found the source of the head-warping heat? I'd be nervous to keep throwing heads at the thing...but you already know that.
gjackson
FRGS
Am I the only one that is unable to see the pics of this rig?
Pics are coming.
Thanks for all the suggestions on the cooling system. I'm being very careful putting it back together this time (making sure water pump is okay, making sure injection timing is okay, making sure head gasket is correct etc). Also installing a second temp sender and calibrated gauge and an EGT. We'll get her working. And I'll take some pics when next I work on her.
cheers
gjackson
FRGS
So this truck has been a challenge. I have owned it for almost a year now, and it is still not on the road. Some may point to the badge on the grill, but it really isn't that simple.
1. When I picked it up it wasn't running. Jim had just put a 300tdi in it, and the owner was selling it for some reason related to marriage.
2. Getting it running was easy. Kind of. Running is one thing, but running well is another. I knew there was a danger that the head was warped, and so it turned out to be.
3. So a new head and gasket and all that junk. Didn't take too long and it was back on the road. And overheating at strange intervals.
4. Due to a mistake on my part it lost the head gasket again. So off with the head and on with a new gasket. Didn't take long and it was on the road again.
5. Then the head warped again. We'll not go into the details, but it was ugly. In the interim I had replaced the fan clutch and verified water flow throughout the system. I had also found and repaired numerous leaks in the cooling system which I thought were the majority of the cooling problems.
6. So a new head again. This time a performance head from Turner along with a correctly reading temp gauge (!) and an EGT. That all went on pretty easily. Discovered that the head gasket was the incorrect one on this change, so replaced it with the correct thickness.
7. What better test than a road trip to AZ? So off we went. For some reason the truck just wouldn't get up to speed. She cruised at 65, happily enough, but over that was a bit of a struggle. But she wasn't overheating, so I considered myself lucky. Then i turned west just north of Santa Fe and the temp began to climb. I babied her all the way to Abq and pulled off for diesel. I called Jim and he recommended running ATF through the engine. (No, not for the cooling problem)
8. Getting going again, the temp came down and I was getting more power. Not much more, but a bit more. I made it to Prescott with only a couple of 'cooling stops' when the temp got on the uncomfortable side of warm. By that I mean 230*, there was no way I was going to risk another head.
9. So driving around Prescott to get supplies for an Overland Training course, I started to get a really nasty rattle from the engine. The sort of rattle you get when a big end bearing is going. Man it was loud! So I parked it for a week and did the OT course, ignoring the RR.
10. Now faced with the possibility of having to transport the RR back to CO I wasn't happy. Did a little more checking on the engine on a friend's advice and found the rattle was an injector not a big end! So back to the ATF idea, which is to clean out the injectors and the injection pump.
11. Decided to risk the trip back to CO even-though cooling would still be an issue. Started off with a loud rattle and a quart of ATF in the fuel. By the time I hit I-17, two things had happened. The engine was running like a rocket, and was starting to overheat again. The slog from 69 to Flag on I-17 is a good cooling test, and it proved that I was not getting enough of it. (I knew that already, to be fair).
12. So just before Flag I pulled over to cool and decided to get rid of the winch. Took 10 minutes, and I had a big hole in the front. And now I had a whole new car. She could pull 75 going up hills and the temp was sitting on 210* and NOT MOVING! I loved it! The extra cooling from the lack of winch and the injection pump cleaning from the ATF had transformed her. Now feeling good, but with a constant eye to the temp gauge I flew past Flag.
13. And then the transmission let go. I pulled over to the side, tried low range which didn't work, and CDL which didn't help. Got out pushed the car slightly listening for diff sounds. Nothing. Seems like the ZF. Certainly not the weakest part on a LR.
14. So I called some expo buddies in Flag (Thanks Andrew!!) and we towed the RR into town. I dumped it, rented a car and drove back to CO.
15. With the car in Flag I couldn't do much of the diagnosis side, so I had some conversations, did some research and got an R380 manual trans on the way from England. Along with all the bit and pieces needed to make this a manual car.
16. Connie and I made a fun weekend getaway down to Flag to get the RR and brought it back on a flatbed. Back into the garage and start the trans pull. I drained the fluids and pulled the access cover off the bell housing and the bolts that are supposed to hold the flex plate to the torque converter fell out. Yikes! No wonder she had no drive! All 4 bolts were sheared. So that makes pulling the trans easier!
And with all that blah blah blah, here are the promised pics:
cheers
