The Baja Bus 1994 FZJ80 Build
Had another excellent weekend exploring Idaho's back country. This lake is about 9000' and is absolutely incredible. The trail up to the lake is super tight and with a little moisture could be a challenge.
I ordered up some air bags the other day and slapped them in before the trip this weekend, I must say they are welcomed improvement to the Cruiser when she is completely loaded down with gear for the weekend.
The work begins next weekend, all the parts are ordered and I will attempt to completely rebuild the front axle and do a cut and turn on the front knuckles as well as new gears for the rear and all new bearings/seals and brakes all the way around. Going to be a crap load of work...
I bought my 94' Cruiser almost a year ago and have done many upgrades to it over the course of the last year. It came time to do another round of PM and upgrades and being it is my daily driver I HAD to get it all done in one weekend. I called up Cruiser Dan and Cruiser Outfitters to get am all the parts and seals I would need to complete the job. My goal was to completely rebuild the axles, install 4:88's, new brakes and brake fluid all the way around, new steering ends and do a cut & turn on the knuckles. Ambitious, yes I know but I like punishment.
I have done several C&T's over the years and on my particular Cruiser I did not have any driveline vibrations, so all I really needed to do was correct my castor. I had some yellow bushings for it, but since I was tearing the axle completely apart I decided to fix the castor the right way.
I am not here to say bushings are bad or plates are a Band-Aid, that has been discussed numerous times in many threads. This is how I choose to fix the castor. The Cruiser drove just fine before, but I knew it could always be better.
So here we go, I started by jacking up the Cruiser and making sure the front and rear ends were level, I did the 4:88's in the back too so I had to pull the tires and everything to get to the back. I cannot stress enough that this step is very critical to get the center of the hubs the same elevation off the ground, if they are not the castor measurements will change. Spend as much time as you need here.
Next strip the axle down all the way to the bare knuckles, again I was doing the gears too so the differential came out, but is not necessary to pull out.
I then took some good measurements of where everything was at stock, pretty much what I figured it was sitting about .5*.
So with all my measurements written down it time to start cutting! Clean the area around the factory weld very good with a wire wheel. I like to make my cut just to the inside of the factory weld. You only need to cut in about 1/8" all the way around. I was able to use a cut off wheel on my grinder for 90%.
The top of the knuckle is a little more difficult to get to with the coil bucket there. I had to use my SawZall to get in there. This is where a good blade makes quick work!
I like to take a chisel and make a horizontal mark across the cut so when I rotate the knuckle I can see how much I am moving it and I can compare to the other side.
Next take a BFH and beat the knuckle back. I like to leave the trunion bearing races in so you don't damage the knuckle itself. I was replacing all the bearings so I was not worried about damaging the bearing race. I know the FSM says castor should be 2*-4* but with the bigger tires I was aiming for 5*. Plus 5* was as much as I could get without the steering hitting the control arms. I put the steering knuckle back on and put the tie-rod back in to check clearance and have something flat to measure off of. You can see how little you move the actual ball to achieve the proper castor.
So it is time to fire up the welder and dial in your heat and speed. Then burn the weld into where you made the cut. I like to weld the ball in quarters doing two welds on each side at a time with a beer in between to let it cool down.
That is pretty much all there is too it. I took me an additional 3 hours once I made the first cut on the first knuckle. A lot of that time was spent taping it back and forth and comparing it to the other side and making sure it was perfectly vertical and matched both sides.
So final thoughts? Well worth it, it drives like my Yukon now and does not wander at all. The gears are great and the breaks kick *** now. Nothing was in bad shape, I just like to know that it will be good for the next 100k miles. It was a **** load of work to get done in a weekend and I am tired and sore, but that will all go away...
Thanks guys, yeah it was a ton of work but well worth it. Well this weekend I rebuilt the power steering pump, once the pump was out it was fairly straight forward. The ***** was getting it out, anyway no pictures as I was in a hurry. The roof rack is nearing completion and looks really bad ***, should be done here in the next week or so.
What is the secret to fitting 15" wheels on the rear FF in the FZJ80?? Specific offset?
Thx
I have a 3.25" backspacing, that is 1" less than factory so its 1" wider per side. I did have to grind the caliper slightly to clear the brake rotor.
Cruiser is all prepped and ready for a week long trip down to Colorado for so wheelin' and time with friends and family. Heading to Silverton tomorrow to meet up with my dad, gonna be about 1500 miles easy by the time I get back. Pictures to come...
Thanks! I just tried fitting some 15x10's with a 3.5"BS but they contacted the calliper hard.
6 Days and almost 1500 miles another awesome trip in the Cruiser. Not a single issue the whole time and the new gears are great on the highway. We arrived in Silverton on Saturday and went up California Gulch and over Hurricane Pass, it actually snowed on us once we got up close to 13,000'. The next day we went over Ophir Pass and into Telluride, had lunch in Telluride and made our way over Imogene and into Ouray. Monday we went to Animas Forks then up Poughkeepsie Gulch. We had some friends in Ouray that are from Las Vegas and he has broken a planter gear in his T-Case so Tuesday we ran Last Dollar from Ouray to Telluride then back over Ophir and into Silverton. The last day we had a few hours so we went up Corkscrew Gulch and back to Silverton. It was a great time.
Snow In July!
Como Lake
Imogene Pass
Ouray!
Mineral Creek
Telluride
Corkscrew
How about a nap at over 12,000', We don't need no stinking trees!
tbnd88
