The Build Has Begun!!
I'm not worried about connecting to city water, other than long enough to fill the tank - I'm building a day-tripper - the plan is to go to a Holiday Inn or similar at night instead of camping out.
Your idea of a recessed compartment with a locking door for the connections sounds good - you could even have some slots in the bottom edge so you could close the door over the hose and power cord to protect them from being stolen.
Hhhhmmmm...I wasn't really concerned with anybody tampering with my water, but now that you mention it it makes sense. I'm gonna start looking for a locking door to cover it.
I was thinking more of something happening in your driveway, or a parking lot, etc., rather than set up in a campground, but these days you never know.
I saw a report on the News a couple of weeks ago, where there was a big rash of items being stolen from campers in pay campgrounds during the night, or while the owners were away during the day. If you think about it, everybody leaves everything out in campgrounds because campers are generally a good bunch of honest people, which now makes it a target rich environment for thieves.
Bob, even if I don't have clearance to recess a box so I can use a flush mount door, I could install the connections in the body and then just make a removable, lockable, box type cover for security. I could then remove it for use, or cut slots in the bottom edge like you mentioned, and use it in place. This would probably look pretty ugly on the side of the vehicle, but in my case it would be on the front with all of the rest of the add on stuff, so it wouldn't matter so much.
EXPO365, are you making any provisions to be able to fill your tank using water from a river or lake, etc?
Some wilderness/off-road type campers I've seen have a second, larger diameter fill tube so that water can be poured into the tank just like adding fuel to your tank using a gas can. With just a garden hose type intake, you will have to use:
1. Gravity - water from a container sitting above the fill level.
2. Hand pump - water from a container or the source.
3. Electric pump - water from a container or the source.
Personally, I will probably just use a second Sureflow pump I have and set it up so that it's portable, along with a couple of extra hoses. Of course you won't' be able to drink this water unless you have a filtering system capable of removing particulate down to 0.1 microns, which is capable of removing 99.9% of all bacteria, such as salmonella, cholera, E.coli, and all protozoa such as giardia and cryptosporidium.
You can always just slide a padlock over your power cord-the connectors are large enough that a loop around a handle with a lock will do the job. Your water hose with a chunk of chain can do the same.
City fill tampering.
I am a Master RV tech here in NJ and I have never heard of anyone having an issue with someone putting anything in there. Nice work on the ambo, expo. I just bought an old 4X4 ambulance myself and am converting it to use on the beach and do some camping. If any of you guys ever have any questions please feel free to ask.
View attachment 295858View attachment 295859
Awesome rig dude, the 4x4 is the one thing mine is missing! I'll definitely be taking you up on that offer, I just fixed a electric issue this weekend and may have a few questions for ya on the next project. Lol
Electrical issues are my specialty. But there's not much in an RV I haven't dealt with at this point. I plan on using it at Island Beach State Park, and to do some occasional camping with the wife. I am out there all the time in my current van. Its an old Quigley as well. Just curious, have you had it out on the road yet? And if so have you gotten any grief from the police about the lights?
I'm back! With some major updates!!!!
It lives again! I had lost power to the house inteior for a few weeks, but finally found a broken wire in the connector on the mod disconnect switch.
https://instagram.com/p/5VI_GdiNhi/
We also finished the on board water system and are 90% finished with the shower setup.
Behind the heat shield for the propane water heater is the factor exhaust fan so when we take a shower it will pull any fumes out of the vehicle.
I also made a shore power cord and plugged in the ambo for the first time last night. While plugged it it has full 110v to all the outlets. I wasn't able to confirm if the inveter is also charging the battery yet tho.
Often, things just pop into my head even in the middle of the night sometimes. It finally occurred to me, that since your tank is mounted in a compartment, it would be an easy fix to add a gravity fill to it, that you access by opening the door. No through the body inlet necessary. Looking at the picture, it even looks like you have some sort of large dia plug in the center of the top already.
It's looking good! Just curious though, why are you painting the aluminum diamond deck white in the shower?
Yea I think the hole on the top of the tank is what I'll be doing, the center plug is a casting plug actually. It's melted shut so I'm gonna just drill a new hole and get a grommet style plug for it. I may need a small fill neck possibly, the sink sits directly above and I need a gray tank for it. I figure the easiest way would be a gray right on top of this one, and have the sink drain straight down into it.
The white is just to make it look nice, the Mrs. Wasn't thrilled with the scratched up Al, and white caulking all over. Hopefully it will hold up, even if it starts to wear off, it's easy to touch up.
It's a budget build but we gotta make it look nice at least lol.
Ah, I forgot to consider the 'Mrs.' factor.... :oops:
********, it's the most important factor to consider. She's the real boss so what she's says goes.
Plus once the lights are sealed and turned on it should make the shower stall super bright.
mbobhat
