Thanks for the compliments- as for upcoming plans, I'd like to build a roll cage looking thing in the shell to help support weight on the rack without spreading the body panels apart at the tailgate. I want to raise the 5100s in the front up a click from .85 to 1.75, and I need to finish the laptop mount/12V outlets/120V outlets at the passenger seat area.
Yeah the lid prop I made after noticing when I take a corner/bump with it open it'll swing down on it's own. The inverter is a cheapo coleman 1200 watt, the saw says 9 amps or so @ 120v, it probably peaks around 11A because I measured it peaking 120A @ 12V while cutting a small tree down in my yard (testing
). It actually works great! I left the two batteries isolated and one odyssey 1200 was able to run the saw intermittent for the whole tree cutting process (all limbs cut up, etc). My household coffee maker draws 80A @ 12V, but since it's a constant load I leave the truck running for that which also means 2 X PC1200...
I'm new to the forum posting and can't figure out how to attach pictures and have them show up in the thread instead of as attachments- maybe they are too big? I'm also not sure how to make them smaller if that is what I need to do!
