The Oshkosh P-19 (Project Dingo)
Baloo
"The Bear Necessities"
Here it is the P-19 build thread. The plan is to remove the water tank and fire fighting equipment and put the box from the ambulance on it. So here we go...
Sent from my SM-F946U using Tapatalk
Deleted Member 183
First off, Please forgive my negativity...
Before you start your truck project I think you should go "ReFi" your house and get right around $100K in cash, then stop by the local liquor store and get a large bottle of tequila & 12 pac of Pacificos, then head home.
Once at home, set the beach chairs around the fire pit the get a good fire going. Then invite a few friends over to party around the fire with you while doing the shots of tequila with the beer backs.
THEN START THROWING YOUR $100K of CASH INTO THE FIRE!
Doing that, You will end up financially ahead!
P-19's are dirty (your state will probably not allow you to register it for road use), slow expensive to run junk! The true definition of a "Land Yacht" (a hole on the land you pour money into)!!!
Petersmithinak
