The Wanderers build
Time to start wiring stereo stuff... first, kick panels
some reassembly required
more so I remember which way I wired the speakers
if I have a guess, this speaker will die a horrific death... ah well, it'll look nice while doing it
don't get why? where do you think a perfect foot rest would be in this Blazer for the driver? This isn't a Corvette so there will be mud, mud holes and muddy boots.
and the wiring
more wiring with wire holders
and back in the car... not quite ready to complete screw them in, but close. One thing, the seat belts bolt through these panels, so they're kind of key
just about ready to take the interior out again
first find the right wire for stereo powering
have I ever mentioned that I hate wiring?
then realize I need more of this
to be continued
rotating back to things I need to finish... plug the hole for the pcv
the problem, the turbo is pretty much over the top of the valve cover grommet for the pcv. so I need to move it up
extension hose
shortened
dei wrap since it's literally laying against the turbo
world's worst picture of it installed
I still need more 1" hose to connect to a yet-to-be-install take off on the intake but far closer now
next up, cruise control... I need to move it up about 1" to clear the dual thermostat housing
in other unpictured news, started undercoating it on Sunday
then back to the world's longest install of a stereo.
I must be getting soft... thumping stereo, a/c, cruise control, heated seats, heated mirrors, rear camera, leather interior....
of course, first, I have to thread this hateful thing in from the back
that dash should be in for real.... even screwed in place
success
the neverending stereo install.... glad I didn't hide wires yet - no sound is coming out
first, the antenna needs another connector, but even so, I'm getting nothing from android play or even bluetooth from my computer....
more parts tomorrow... need another fuse for a power wire and an antenna adapter....
bright side, it does connect and the mapping works
because it doesn't weight enough already.... some 3/16 plate to protect the fuel tank
adding a switch for the seat heaters
3/4" hole is just about perfect
took a 9/16 socket to drive it in place but fitz
now with less exposed wires
stand for the amp
now black
tomorrow, hopefully, I'll get the new fuse panel for all the extra stuff I've added to this rig.
continuing with wiring
wiring the main power feed
passenger side wires are hidden.... next up is a j-box for the power feed and ground strips
pictures of now
then next up is figure out the box for my phone and light control
picture over this a custom console.... but the wiring portion of the stereo is done.
well, sort of. Next is a new fuse panel to run the key'd switch stuff like heated seats, heated mirrors, trail lights....
my goal is by Sunday have the seats in...
test fit the gas tank skid plate.... nice piece, just need to finish welding it
went to the wrecking yard today to get the ball cooler
time to fix the fan shroud
remove fan
and done
onto the a/c system....
I have to adapt the new pump to the old system
crimp tool
all crimped and ready for vacuum
and finally, knock the skid plate apart, put it together so that it looks better and I can tig it
2eleven
