The Wanderers build
time to make lights
but first, colorful spaghetti
of course it means taking things apart (again)
need to install the controller for the heated mirrors
we have light
hottest day of the year and I get the heated mirrors and heated seats working....
of course, the dash bezel doesn't fit with the leather-covered dashboard
so more to do.... but I really am getting close on the electronics
yo speedhut, where's my tach?
Maestro in action
[VIDEO]
for those who wonder what the alternator sees when using an alternator based tach signal
picture for those afraid of youtube
back to important installs
that was rough
this, on the other hand, was a bit harder
but it's in and for the first time since I owned this truck, the driver's side is done(ish)
next fix
with just a bit of disassembly and reassembly
it's time to start tucking wires but then, rear window acted up again
to be continued
I find it interesting that out of 6 or so motors that I've built/upgraded/owned that this is the very first that needed the hose clamps for the bypass hoses.
though, in my own defense, the hose I used initially, failed.... though why it had to fail in the hardest spot to fix? yeah..
for those counting, 4 hours to replace 3 hoses.
onward, back together but I think I'm going to add a second layer of heat shielding - of course, all of that and the next project is still in Kennewick
back together. one of those smart things I did was create this head pipe with v-bands on either end... makes work so much easier (not easy, mind you)
so the next deal - the rear window issue
see the witness line on the glass, the arms are hitting the lip and trying to pull it off the glass.
the fix is take it apart and reattach the glass to the track with it bent more to the front of the vehicle.... or you can try to whack the mount while it's attached to the glass....
I'm not that brave so I put it back together and I'll just remember to pull the glass so it clears the arm while it's going down
time to charge
it's not holding a vacuum long, so some help
but first, time to wire the compressor
and done
and now wired properly
however, these things....
if you look close, a bit of fluid is under it.... bright side is no other leaks...
and it did blow cold - so we're on the right path
to be continued
and continued still
the way life works for me, I put this on backwards and it was the other side that leaked
I think what i did was put the seal in backwards on the correctly built side
if you squint closely, there's a thinner end and thicker end of that seal... of course, I can't check that because the one that failed has gone into quantum space
so I wait for my order of a new one to arrive....
not wanting to completely fail, I continued my prior fail and finished it without fail
I bought the wrong inserts - got the right ones so finished this up. This gives me a camper connection and also I can hook high-draw stuff to it (like inverters)
while waiting for parts, time to finish this up
trying again with the same thing hoping for different results....
so it doesn't seem to be leaking and held vacuum
not perfect but as I'm still not ready to declare victory, I'll add 2 ounces if it's still up tomorrow
time to fix this rat nest
much better... just need to find the plastic bits to clean this up
console
doesn't fit
finally fixed the seat belts (were installed wrong way)
thought briefly about this but it makes heat and mounting two big problems.
oh chinesium, you can't even crimp a wire
soldered
Install the glovebox, hopefully for the last time
still looking for a leak, I think I'm going to go to a pro
time to shorten wires
thankfully, I have a DT connector kit
first cut down
then put new pins in place
on the other end, need to connect to power - these really are a fancy design, you can rig them to come on with the brights, but that's not how I want to run them
first solder the power feeds together
lights are now on - nice thing is you have 5 levels of brightness, you can run them as lower power fogs up to 'burn them into their seats' brights
low power
slowly making all the wires disappear and accessory start working
so the chinesium heated seats plug pulled apart - thankfully I have the other side to copy where the wires go
bonus, it works
ARP light controls.... out here, people seem to think they're funny if you flash to remind them to dim - that they turn on more lights.... I have more lights x5 from driving light to leaving just a shadow in their seat full power
just one more hole to fill (ashtray)
did other stuff but picless light aim headlights (and put one right side up), mount the coolant reservoir...
and this has to be a record for me. I get reasonable offers for my collector cars with remarkable frequency, but never before it's done... smh...
and no, this is my next daily, not for sale.
still struggling with the a/c, need to cut and buff it, wire the backup lights, wire the radios and put in their respective antennas.... tempting, for sure, but no. It is an ego boost, though, because it would actually pay me something for all the hours as well as the parts....
2eleven
