The Wanderers build
back to the interior.
to remind, this is where we were a couple weeks ago
I don't like square switches because their an utter PITA to make a switch hole for... so let's do this with a regular momentary on-off-on switch
basically I just have to switch polarity to get the linear actuator to work correctly
now wired
now to make enough room for a ... phone... yeah, phone
let's lay out a new liner
wish my shear was out of storage
now clean up the weld spots
and paint the insert
then tack into place
and painted
side view
paint is drying, I'll install tomorrow.
Installation pictures
works great
holds a phone just fine
except... I suppose I should just shut up and leave intact the notion that I know what I'm doing but the first attempt was not successful - the actuator hit the hvac hard enough that it wouldn't close
to remind... actuator in the back
no big deal, I'll just attach it to the front
except that doesn't work either (again, interferes with closing) Strike 2
so let's just move it right in front of the back bend
winning and he hit it out of the park
that worked out pretty good because you can half open the door and your phone shouldn't come flopping out under normal driving
not going to use the charge pad, it takes too much room, is too long, and works just fine on the dash or in the dash cubby....
It cracks me up this.... 6 1/2 month old English Mastiff 115 lbs. Same "I can't believe you did this to me!" what did I do? well, it was raining. He didn't want to go out in the rain. It was my fault I didn't make it stop and rather laughed at him. I may have to revise my estimate of how big he's going to be... I thought 190-200, now it's looking like 230 or maybe a cheeseburger more....
I bought a F250 stabilizer for reasons, but one of those problems is this bracket won't work because I need a wider spread between it and the attachment point on the cross shaft
cut it off
clean the weld surface
weld new bracket to it
now installed
now those reasons: 1) the Ford stabilizer has greater travel, 2) I can adjust it's dampening by changing it's charge, 3) it's a larger tube diameter which helps initially and doesn't overheat as quickly (the biggest fail of any shock is it creates heat - the hotter it gets the less it dampens but rather then getting softer, it gets far firmer - thus, if you think your truck is beating you up after a few miles offroad... stop, let the shocks cool - or get coolers... etc).
Did you design their prototype?
Sent from my Pixel 9 Pro XL using Tapatalk
no but I'll certain borrow some of their ideas ;)
in other, unrelated news, new plow truck. it looks far better then it is.... but it'll do
but this is the related - that canopy is history, and if someone needs a long bed, tall canopy for overland purposes (or flowerpot, don't care).... let me know... you need to fetch it from Sandpoint, but the price will be quite attractive to those who like free things.
So, snow is supposed to be here Thursday.
but first, the distributor arrived
pull the old out
but that wasn't the end of problems... no picture, but the truck has 2 tanks. I filled one.
Guess which one wasn't hooked up?
my guess is the switch went bad - so they just connected one tank. This truck, backstory, I bought from a widow. She had a new guy and he came with his own truck so this was surplus. I think he tried to make it run, but he wasn't the only person who messed with it as the title isn't her dead husband's name. So I hooked up the tank with fuel and it ran (ish). They said it sat for a couple years, I think that couple years is just like 'a couple beers' people tell cops when they've been drinking. But, good news is with running it a bunch, it now runs fine, still down on one cylinder but more like 50% down so it runs and drives just fine now
The other issue was the ignition switch required serious effort to get it to twist, so I replaced the module on the column
finally got around to cleaning out the back and getting the other snowplow out
and it still looks like an old, abused truck
but the plow is off and about ready to go up for sale
and people wonder why it takes me so long to get stuff done. Driving home last night, the dually was running like it was out of fuel. Turns out, after diagnosis, it was this
such junk 280,000 miles and 35 years old it died. What American junk
I would, however, like a word with the engineer who felt you needed to take half the top of the intake apart to get it off
and finally, we're to the snowplow install.... what is this, 9 posts and 4 months since this saga started?
take a look at the future
I hoped to just turn around these brackets and call it a day, but nope
looks good at this point
just hangs way too low
tomorrow, make a couple brackets to weld to the frame and bolt it all together
bracket lifted into place...don't like, not square and a bit low
cut back brace off... don't think I'll need them but we'll see... better
I really need to find my pipe clamps... but alas, use what ya got
my new plan is trim the inside of the frame rails and simply weld this all into place... it's an old plow, an old truck and frankly, I can't imagine a case where this won't be used until it vanishes in a pile of rust dust.
move back about the width of the brackets... I may extra brace, I may not, because where it's going to be welded, all the force is basically in line with the spring hangers - floating may be an issue (where the plow doesn't have down force but simply floats over the ground) given the arms aren't parallel with the ground; however, if I did that, the bracket would be 6" off the ground and a hazard
so with just a slight notch
it all can be installed
after the notch, much alignment was done... this is probably fit number 5
basically I used the assembly to decide where it all fit
welded the lower bracket to the frame, then bolted the upper bracket to the lower bracket and to the frame. The upper frame keeps the lower frame from rotating under the vehicle.... or at least that's the theory
one of the joys of making junk fit...
I have a plan.... it should be just fine
what's left, put the controls in the cab, wire the various lights and pull the bar forward enough so I can open the hood... oh and put in new belts (I know, I know, there goes the budget)...
all in, $1,800.
As Ford and GM used the same pump, this basic primer explains how a DB2 (mechanical) diesel injection pump works. For those following along. Squarebodies and OBS to 1993 used mechanical pumps...
It's funny, with the loss of being able to find mechanics to work on these motors, there is a great surge of YouTube videos ....
this one is important because it's an issue I have right now
a tail light didn't work... found the problem, someone used wire crimp connectors - and basically cut 2 of the wires in half and the other two were hanging by a thread... no post but I simply used bare wire connectors then covered with heat shrink
what a pain
2eleven
