The Yeti (Quest for the perfect SMB)
Custom coil springs and fox shocks that he personally re-valves in front. Custom shocks in back with add a leaf and a custom bent bottom spring. It slightly raises the van and prevents the common bottoming out the Quigley's are know for. I still can't believe how bad the ride was before. It is amazing now. Here is the website:
http://agileoffroad.com/
TexGX
V10's get much less. I say most people report 10 to 11 tops and will never see 19 like I sometimes do. My Van is about 9500 lbs. So it is pretty heavy for a RB.
TexGX
This weekend worked on the side door cabinet. It used to be that the larger door opened up for a table inside. I wanted it down for a work station when outside. Here is the finish product:
Doors closed
Doors open. I used a piece of then aluminum to protect the back of door from heat and water.
TexGX
Sweet...u don't happen to know what is the height of your smb? Does it fit in a 8 ft garage? Thx again!
MOLLYmaz
