Got lots of emails thank you..... I am the second owner, it has a clean/clear title. 5:13 gears, 3"lift, 35" nitto trail grapplers, 30 front, 44 rear, front &rear lockers, upgraded drive shafts, larger u joints, upgraded axels, transmission cooler, SB front bumper with 12k winch, Rockhard rear bumper, with gas tanks, & rack, 5150 shocks , teraflex speed bumps on all 4 corners, larger rotors and brakes, truck lite led headlights, on board compressed air tank and a on board compressor. The jeep burns zero oil, the trans shifts like new.
Trailer is similar set up: 20 gal water tank, on board propane, on board compressed air tank, two 6 volt deep cycle batteries, power inverter, electric top opens with the flick of a switch, (see picture, the inside of the trailer is coated with por 15) it will come with the CVT RTT, spring over axel with new Goodyear tires on method rims. This trailer would cost 8k or more if you went to buy one. Paint matched perfectly to the truck.
The only reason I'm think of selling this is, I just bought a 100 LC and I think I want to set it up in a similar fashion. The jeep will go more places than I really want to go and the LC is probably more suited to my style.
