Redline
Likes to Drive and Ride
I would like some opinions on this used Tacoma. It belongs to a friend, he’s selling it, but not in a bug hurry, he has a new Duramax and the Tacoma isn’t being driven much anymore.
I'm car/truck shopping because I like to, not because we need another vehicle. My wife has a very economical 2000 VW Golf TDI that she drives, but this truck would be her winter/snow vehicle and also used for haulin' our three dogs around when needed. It could eventually do back-up Chaser pulling duty, but I have an F350 for heavy haulin.
Truck:
2001 Tacoma 3.4 V6 TRD (rear locker)
Crew-Cab pickup auto-trans with 101,000-miles on it.
Has a Leer shell on it.
Stock Except for shorter tires on it (245/75R16 I believe)
After break-in, Mobil synthetic was run in the engine and changed every 3,500-4,500-miles. Around 70-75k my friend started using Mobil's Extended Service 15,000-mile oil and changing it every 12-13,000-miles.
This guy is your typical 'car' owner, has his oil changed at Wal Mart or a quick lube place, and has probably done little else to maintain the truck other than these oil changes (maybe none was needed?). No oil analysis, just running the longer change intervals because Mobil says you can. The 3.5-4.5K intervals are not a concern, but the 12-13K intervals of late do concern me.
For the record, I'm not totally against extended oil drain intervals with a good filter, premium oil and some mechanical awareness thrown in. I use the factory recommended 10,000-mi. oil change interval on my wife's Golf, using 5w-40 synthetic diesel oil. I'm also considering extending my V8 4Runners oil changes from 5k to 7,500-10,000-miles WITH oil analysis, all with the same Red Line synthetic I’m using now. Just not sure about his “it says 15K on the bottle so I’m fine if I change it at a bit less than 15k” attitude. He could be correct and the engine could still be in perfect shape.
He will sell it to me for $10,000 (maybe a little high, but he often thinks his stuff is worth more than it is).
Kelly Blue Book price is $10,300 if it's in 'excellent' shape, Good is 9,500.00
Do these things have 15 or 16" wheels?
I know the 3.0 V6 was not Toyota’s best engine, any big flaws with the 3.4L?
James
Truck:
James
