HI All,
A NOTE TO ALL: PICTURES HAVE BEEN DOWNLOADED. SEE POST 58 BELOW.
I’m a brand new member here. So, I’d like to say “HI”. Sorry for this long initial post.
I’m going to hit you guy’s with a difficult question I’m dealing with. Weight. Not me, my Jeep. I have an ’89 YJ, 258, soft top. It was bone stock when I bought it 10 years ago. I had a plan for building my Jeep for expedition use and it has taken me 10 years to get to the goal. I have reached the goal but this Jeep is heavy. My question is, is it too heavy?
I should post some pics to give you a better context from which you could comment. But, I just got it all together and haven't had time to take pics. I'll try to that that done this weekend.
Here is the situation: Jeep specs the curb weight at 3,200 lbs. Jeep gives it 800lbs. of load weight. So the total weight capability Jeep gives is 4,000 lbs. They also say it will pull a 2,000 lb. trailer but that a question for another day. Suffice it to say that I have 1,500 lb. Aliner trailer that I have pulled with this Jeep.
I weighed my Jeep today. It came out at 5,020 lbs!! I’m about 1,000 lbs over the maximum weight. I maxed out the load before I visited the scales. I had a full fuel tank, I was sitting in the vehicle, the roof rack was fully loaded, and the interior was outfitted for a trip. Four Gerry cans, two for water, two for gas were mounted but not filled. In other words, the Jeep was ready for a trip except for the empty Gerry cans. When filled, they will add about another 140 lbs. to the rear of the Jeep. I can’t carry passengers because the rear seat has been replaced with a Tuffy trunk and my ARB freezer/refrig resides where the front passenger seat would normally be. This is a single person machine.
I use four Pelican cases to carry my camping gear on the roof rack. For the most part I use backpacking gear to keep the weight and size down. I have fabricated custom mounts for the cases. They are very secure. The cases can removed when not needed. No bungies here. Access to the cases is by a collapsible ladder that is also carried on the rack. The total weight of the cases, filled for a trek, is 111 lbs. ,including the weight of the cases themselves. Also on the rack is a Pull Pal, a small table, a self-inflating sleeping pad, and the Gerry cans. The rack capacity is rated at 300 lbs. I am under that by about 50 lbs. The rear basket carries a cooler and a chain saw.
This vehicle is heavily modified for the purpose I envisioned. I’ll try to give you an idea of the mods but I won’t try to be complete. There is much more but of small weight significance. I have worked hard to have an adequate load capacity and still maintain a low center of gravity. What I list are those items I intended to make this weight manageable. Frankly, it weighs more than I planned.
Weight and Performance Managers
1. Cooling: three row radiator and high capacity water pump
2. Brakes: Hydraulic assist with a Vanco system; High temp pads and shoes; the brakes work well with this load, about as good as when the Jeep was stock (Aside: my trailer has brakes)
3. Suspension: Skyjacker 2 ½ inch lift. The springs still have curvature. They are not maxed out but I am loosing lift. May upgrade to OME or custom from Alcan designed specifically for this load. I won’t go higher than 2 ½ inches (loaded) or larger than 31’s. I want to follow the OME formula.
4. Engine: Howell TBI fuel injection with Safari snorkle; otherwise it is stock
5. Electrical: Dual Odyssey deep discharge batteries and 160 amp alternator. Important for the winch
6. Front bumper: Warn with winch mount. The winch is a Warn 8270
7. Rear Bumper: Tomkin with swing out carrier and rear basket. There is a hitch receiver
8. All axles are upgraded to high strength units
9. U-joints: Front u-joints upgraded, front drive shaft stock; rear drive shaft is a custom Tom Woods SYE with CV joints.
10. Diffs: Ratio: 3:54; front and rear ARB locked; Front is Dana 30; Rear; Dana 35
11. Transmission: NV3550; better load rating than the stock AX15
12. Clutch: Centerforce
13. Fuel tank; stock 15 gal. Can’t do much about this.
Well, what do you think? Will this Jeep be reliable and useful especially in off road situations given the weight? I have driven a local, rocky trail with the full load. The Jeep performed well but it is the long haul trails that are important. What is your experience? I am also concerned about highway use since this Jeep is never trailered. I appreciate your ideas and thoughts.
Thanks, Sparky
Thanks, Sparky
