Trailer lights
Martyn said:
If enough people are interested I can get some pricing on the LED lights we use;
6 inch Oval Stop/turn/running with grommet
2" round side markers with grommet, red and amber
Surface mount side marker with steel bezel, red and amber
Surface mount Jeep style Stop/turn/running with bracket, left and right
It needs to be a special Expo order all placed at the same time and shipped out on the same day to make this work for us.
I'll be down at our warehouse tomorrow and will take pictures of the parts and post pricing. I'll post details of how to order.
That would be great but I need 24V lights... I may get a couple sets of 12V though to have just in case I sell the trailer. It would be an easy swap.
Thanks for the great offer!
I'm interested!
That would be great!
:sombrero:
Here is a selection of lights we have in stock. I'm sure it will come as no surprise to any of you that they quality of the lights is extremely high and the price is more than you would pay at a truck stop.
All the lights are rates 8-14 volts. None of the prices include shipping and handling.Pricing is for single units not pairs.
License / Utility Light
3 LED license plate light
8-14 volt
52000W $5.19
Oval Stop, Turn, & Tail light
10 super bright LED with reflector
Polycarbonate lens, housing sonically welded
Includes Grommet and Plug
8-14 Volts
6 ½ X 2 ¼ X 1 ¾ (depth to back of plug)
32608RK $13.89
Submersible Combination Light
Meets DOT requirements for Stop, Turn, Tail (12 LED/.
Side and rear reflector
Side Marker (4 LED)
License Plate (5 LED)
8-14Volt
4 9/16 X 4 9/16 X 2 7/8
32100 W/O License Illuminator $19.06
32100L with License Illuminator $22.90
Mounting bracket Submersible combo, black
441800 $4.30
Plastic License Bracket for Submersible combo.
9 X 4 31/32
51009 $2.50
2” Low Profile Clearance light / Marker Light
9 LED polycarbonate lens housing sonically welded
Grommet and plug
8-14 volt
12206AK Amber kit $6.82
12206RK Red kit $6.82
7 LED clearance / side marker Amber only
Welded in Epoxy
8-14 volt
12103A Amber $6.31
Light Guard for 12103A
Stainless Steel
90110 $3.00
E mail me for an order form martyn-at-adventuretrailers.com
FourbangerYJ said:
Martyn, is that your normal price or is this pricing for group buy?
We don't normally sell the lights as separate items from the complete trailer.
I asked the manufacturer what a normal mark up was and they said 100 - 150%. I added a mark up of less than 50%, so I guess it's group buying rates.
I should add that these light do not have built in reflectors.
I'll take some pictures of the flexible reflectors we use and get a price on them.
Guys, these prices are very reasonable. I know what I pay through my own whole sale account and like I said Martyn's prices are great for what you are getting. If you're interested I would buy the LED lights and never look back, unless it is at night and it just makes you proud to see your trailer all lit up instead of blacked out like 1/3 of the trailers on the road.
Mike
just add'n my 2cents worth .. I work for a construction company & we have 15 or so dumptrucks and dump trailers .. we have switched all of them over to LEDs because #1 they seem to be brighter than a regular 1157 bulb ... this means they glow even if there is mud spray on them #2 with multiable LEDs(bulbs) as stated if 1 or 5 burn out you still have lights which may keep the boys in blue or DOT away ..... just t 2cents & something to think about
FourbangerYJ said:
If you run LED's on the trailer and don't have them on your tow rig, do you need to swap the flasher so the blinkers work correctly?
I have had three different trailers with LED lights and everything works fine without having to change the flasher on my 04 Tacoma. my buddy has pulled my trailers with several different GM trucks with no problems as well.
Thanks for the info!
The reflectors we use are self adhesive and flexible.
We use 4 red reflectors, two at the rear and two at the side/back on frame rail.
We use 2 amber reflectors that we place right across the bend of the tongue and frame rail. These are standard DOT placements.
Reflectors are $2.00 each
Camp Tonneau Tents
