Trailers...How do you connect?
Mc Taco said:
Martyn,
Does the Lock n Roll provide extra saftey for on highway travel as well? Like if a trailer is getting squirley (technical term) it won't roll the tow vehicle?
Thanks,
Stuart
Stuart
That would be our take exactly. There are some situations with a regular coupler where the trailer can apply torque to the tow vehicle If the tow vehicle is in an unbalanced state that extra torque may be enough to roll the vehicle.
I can think of three instances where this has occurred and the Lock-n-Roll has saved the vehicle from rolling. No scientific proof just the opinion of the drivers.
Martyn said:
The lock-n-roll can not be locked as it needs all three axis to rotate.
Off-Road yes... but some might argue that on the road you might want to bind the hitch in one axis (so that the trailer cannot roll among its length with respect to the vehicle).
Martyn said:
A non rotating pintle has a single axis of rotation and all the other movement it allowed by the free play between the lunette eye and the pintle. I don’t have exact number in front of me but from memory articulation is 45’ versus 15’ with a regular ball.
I think a non-rotation pintle would have two axis of rotation, with a 3rd if using a rotating pintle. I have a rotating pintle with a lock in the axis I describled above. Though I have zero data to prove it helps with any handling issues? There must have been a logical reason why they were designed as such but not one I can think of.
Excellent info on the Lock/Roll... I've been extremely pleased with my rotating pintle - lunette setup, but I think my next trailer design will use a Lock and Roll if for nothing else to eliminate the noise! Great info regardless :cool:
Martyn said:
Lock-n-roll does have a lightweight coupler with a rotational limiter (45') but it's designed for ATV and Jet Ski trailers. I for one wouldn't feel happy having a rotational limiter on a regular trailer.
Any idea why they would include this? Do they think it might actually prevent a trailer from flipping in some circumstances? Again, I have zero data either way, just intersting that Lock-n-Roll would design a setup.
A feature that I designed into my similar coupler (b4 I discovered the Lock-n-Roll patent) was a shear pin. My idea was that if the wieght of the tow rig could prevent the trailer from rolling, then it should. If, however, the trailer's inertia threatened to roll the tow rig then the pin should shear and save the tow rig from rolling.
Since then I'm starting to think that the way that the rotating lunette's work is a better idea. Set up correctly the spring would provide damping in the roll axis while still allowing motion. Does both functions with no broken parts!
Interesting thought. How would any dampening be effected by trailer mass, and momentum?
My first though would be that the spring dampening effect, as the spring is in the same axis are the rotation, would be overcome by the mass of the trailer, rotational inertia and momentum.
I think I need to think about this over a cold one! :beer:
LukeSkywalker515
