So. much. weight. The higher you go up the higher you COG is. If you could find a way to mount is as low as possible, using the rack and w/o load bars the better.
I have seen people cut the top rails off the back portion of the voyager racks so they are able to mount an RTT directly to the floor. That is what I would do if I add an RTT to mine, but I plan to go with a teardrop trailer instead.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
