what did you do to your trailer today?
I put the 3rd (and final) coat of Epoxy on the underside of the floor. Next step is to paint on the bed-liner and then screw it to the frame.
Which one...the Willys Truck bed trailer , I got tail-lights hooked up and working and made a flip up license plate ....the flat-bed trailer I looked at....
Look at My build, I bent this mount at work.
It worked out great! and was almost free "lunch for the press operator"
The pin mounts are clevis pins from the hardware store.
Perfect! Will 5 gal tank run grill and tankless water heater for a while?
The 5 I have does run for a good time, I am adding a hot water system and will add a 20# tank.
I have more faith in swapping the tank at walley world or the local gas station then finding a refill location.
I have cleaned the dust of winter off, swept and vacuumed. Perfect weather- Now- to find time to Go! WMAC, I feel ya brutha!
D
I think propane bottles are measured in pounds, though they sell it by the gallon. I think my 10 pound tank holds a little under 5 gallons.
I started with a 10 pound, then added another.
Water and stove should go a long time on a 10 pound. I run a heater during the winter and it uses much more fuel.
My recommendation, is to try what you have an allow for space to add if needed.
Mounted a side table. High enough to keep the dogs from surfing.
Moved my jack to the side so I can mount a hith box.
Bottle Opener!
Fininshed mocking up the doors. Now to get the heavier steel for new doors.
Connected the front light to the battery. I am gonna put a solar charger on the
motorcycle battery to keep it fresh. Ordered a smaller water tank. One I have is too large.
nahuebsch
