Winch options: TS9500 vs M8000
Yeah Craigslist guys are on some strange substances sometimes. You can find 8274 used for $300 or less sometimes. A bit of love and they're functional again.
I like fast line speed so you don't run over the line once the winch gets you moving again. Nothing worse than stopping and getting stuck six times on a long slick pull because you had to keep stopping to let the line spool in. A fast winch lets you keep crawling up. The other thing it does by keeping the slack out is save you when you slide back. Sliding for 15 feet till the cable stops can break the cable or not stop you from going over or getting in bad shape. It's an expensive option to get a fast one but if does as I described for you on the side of a dangerous mountain it's cheap.
Got my m8000 finally. Thanks for the advice!
Sent from spaaaaaaace
Wolfbox
