Would somebody let me in the cooler secret?
coloradocarlisle said:
Dont store in your tent or truck
I usually keep my cooler in the car, especially when away from camp, and even at night. On rare occasions I've put it on the roof rack at night. This is to keep it away from critters, whether it be nimble fingered coons, or heavy handed bears. However if it is a sunny day and everyone is hanging around camp, it makes sense to keep the cooler in a shaded ventillated area.
paulj
Picked up a new cooler yesterday...a Coleman Ultimate Uber Super Duper Extra Extreme Marine cooler (now with additional superlative descriptors). After peeling the Ultimate Super Uber Duper stickers off, I got to looking at the inside.
Looks like with the purchase of additional adjectives, they include a cutting board sort of thing that doesn't quite fit on the shelf and doesn't quite sit in the slot on the inside left of the cooler. There's also a sliding tray that isn't really held in place by anything...one good shake and it's in the bottom.
Enter "Colorado Plastic Products". They sell scrap by the pound, and polycarb can be cut easily with a carbide blade. Polycarb = Lexan, what those indestructible Nalgene bottles are made from. Polycarb comes in colors, clear, opaque, whatever. It's easy to work with, won't shatter like acrylics (ie Plexiglass), and cleans easily. It can be used as a cutting board as well, as it's resistant to abrasion.
One piece will turn in to a divider, fitting in the slot on the inside left of the cooler. Now I have two deep compartments, great for storing block/bulk items or ice in the large section, and food in the small section...or block in the large section and cube in the small section. Next, a large layer fitted to the lip on the inside of the cooler. On the marine cooler, there are actually two lips, one is about halfway in, the other is near the top where the "built in tray" normally sits. Either would make a good divider...food on the bottom, sealed block ice on top, a couple of holes in the divider for air circulation. Now the cooler has three separate compartments, if I want.
They're checking the scrap bin right now to see if there's something laying around that's the right size :).
I have used the three cooler system mentioned above.
Cooler One; Drinks snacks and that days dinner
Cooler two; Remaining food items, freeze as much as possiable.
Cooler Three; Extra Ice.
I never open the third cooler until needed.
The first couple of days only open cooler two once a day to get dinner and snacks out for the day.
The next couple of days repack everything from #1 and #2 into a single cooler.Keeping the coolers full is more efficient.
The last couple of days replenish ice as required from the last cooler.
All my ice is drinking water. I use a mix of 750mL and juice bottles. Go ahead and put those .750mL bottles straight into the freezer full, they can take it. I also keep my home freezer full with the squarish cranberry juice bottles. A full freezer works better, less dead air space to cool down after you open the door. Funny that it works at home too, huh?;) In the field I re-fill the 750mL bottles from the juice bottles.
As mentioned above covering the coolers with blankets etc helps a lot.
Minimizing the amount of fresh foods is also helpfull.
I often keep my ice chest in my drivers side floorboard as it keeps it close at hand and helps to extend the front seat area to make a nice bed/platform for my 4-legged travel companion.
I've noticed that in the warmer months the floor board gets quite warm especially if I'm on a technical trail moving slowly in low range.
If you keep any of your coolers on your floorboards in the front half of the vehicle where it would be pretty close to the engine/tranny heat, stick your hand under the ice chest after a few hours and make sure your floorboard isn't heating up the bottom of the cooler.
Also, one small thing in regards to freezing bottles........I often drink from mine as they are melting to get a nice cold drink. I find that if I leave an airspace in the bottle before freezing it that the expansion of the ice compresses the air and pressurizes the bottle. This sometimes results in water going all over when I open the bottle.
Instead, I fill the bottles about 5/6 full and then squeeze the bottle bringing the water line up to the neck. As the water freezes it simply expands the bottle as needed.
not sure if it was covered but ... i've gotten relatively good mileage out of the "blue ice" packs from rubbermaid. they're self contained and re-usable; seems to stay cold a bit longer than water. could just be my imagination though :)
i've vowed to stop bringing beer or iced drinks on trips, but a bottle of wine just doesn't have the same satisfaction of a cold one at the end of a hot, dusty day.
someday we'll be cool and join the arb/engel ranks :elkgrin:
2eleven
