WTB; red Scepter fuel cans
mk216v
Der Chef der Fahrzeuge
Aren't these the same as RotoPax? They're listed as for sale at quite a few places.
Herb
Hi Herb,
Never seen RotoPax until now--pretty innovative. Looks similar but RotoPax are only 2gal each.
Geri's hold 4gal(would like to see them hold 5gal).
mk216v
Geez, looks like in an emergency you could use it as a sand ladder or makeshift stretcher. Not that I'd try it ;) Only problem is it doesn't fit in a standard fuel holder.
Hehe, I thought sand ladder too when I first saw them. :)
They do hold up to 800lbs of weight they say. Too little for my 5500lb G.
jeeepguy
They are stackable and connectable. You can stack three 2gal units on a standard carrier. You just need to use a strap to hold them on.
mk216v
mogwild was talking about the full length red Geri's(4gal).
Are you saying that you can fit 3 of the 2gal RotoPax in a standard carrier that would hold like a 5gal Scepter? If so, then that's an extra 1gal capacity (6gal w/ RotoPax vs 5gal Scepter).
Do you have any pics of this? I'd love to see. Thanks!
surfponto
Ditto. I was pretty floored.
Putting the money towards new tires but since I want 33's I have a ways to go.
personally I would just pick up a few of the Desert Sand Color Scepters which seem to go a lot cheaper. Just swap out the gasket with a Viton gasket.
You could even order a red strap from DS Tactical if you want to designate gasoline.
Bob
Wow Bob, $137.50 on ebay. I would have never guessed it'd go that high.
Damn, for that price I'd pick up two new red Geri's (anyone ever use those?);
http://www.expeditionone.biz/geri_main.htm
Anyone else have any less expensive red Scepter's up for grabs? :D
mk216v
Bob
Yeah, looking like either Sand Scepter's w/ yellow strap and rubber gasket (I'm diesel) or the RotoPax's.
surfponto
If you use Bio-Diesel you should look into the Viton gaskets, as I have heard it will deteriorate the rubber gaskets.
Probably in higher percentages though. B20 may be fine.
mk216v
Ok thx, will do.
If I run bio it'd probably be B99.
Clemtiger84
