family hauler
warrpath4x4
put the water pump and the pulley on tonight, pulled the radiator and fans out of the boxes
here you can see where im going to have to trim the shroud
warrpath4x4
Looks great!!! I'm planing on building a cowl induction hood for my K20. I have it all worked out in my head(o; What does the under side of your hood look like. Need a picture for reference.
Thanks!
~Wes~
its a steel hood
Wes
Thanks! That looks pretty straight forward. They didn't even change the bottom reinforcing grid.
~Wes~
warrpath4x4
ordering new radiator bushing pads, chevy dealer says they dont make them anymore so im ordering a set of 4 poly ones from summit for $13. the bottom 2 in there now are limp like wet noodles and the top 2 are missing and had a rag shoved in for one.
warrpath4x4
installed the radiator and electric fans, got them wired in sunday (main comes on with ignition and secondary is wired to a switch). my bushings showed up lastnight but i got off work to late to put them in, hoping i can get them in tonight.
so sunday i put it through its paces to see how the new radiator was gonna work. around town it was fine, but the old radiator was fine around town. so i headed up white mountain which is right out of town and a bumpy rocky road thats about a 70-80 degree climb, it started to warm up a little and as soon as i hit the secondary fan i just watched my temps drop back down. next test was the freeway, it would heat up going down the freeway even with the heat on, now its nice and cool even with the A/C running.
warrpath4x4
looking at putting the two fans on thermostat switches so i dont have a fan constantly running in wyoming winters.
tonight i got my visor mounted, and got the bushings put in for the radiator.
warrpath4x4
i took the wheels/tires off he blazer to swap the new tires on the blazer wheels, and put the suburban wheels/tires on the blazer.
the only way to change tires
rear brakes look good
mounted my visor the other day
huntoon
Wait... What? 70 degree climb?!
Clemtiger84
