LJ Rubi Build - From total loss to total custom
Mudicon
Have trail...will travel
The problem with the current top, is age, color, and no back window. I am old, so I can deal with age. Color can be fixed with vinyl dye. The missing rear window…that appears to be the major problem. I gave the original top from this LJ to my son, LJRunner05, for his LJ, and planned on running a hardtop on mine. Due to 2 specific circumstances, sun loving girlfriend and hardtop unavailability, I am in need of purchasing a complete top...unless you fine folks know anyone with a rear window for a TJ or LJ...
Mudicon
Ok...I promise to post build pics tomorrow...but I have to upload a sneak peak tonight...introducing SASQUATCH :wings:
Beowulf
I bet if you post a WTB over on Jeepforum.com, you'd find someone with a rear window. I thought you could buy them separately as well, but used will be more cost effective.
CRolandLJ
You could also try davey's (the online jeep salvage yard)
They seem like nice folks and sell individual parts all the time so i'd imagine they'd get you a back window if you asked for it. Only thing i've ever gotten there was new to me passenger seatbelt.
Mudicon
I know it has been a while since I made any great process, but I have been down with pneumonia and have not exactly been able to work on her. Finally last evening I was able to haul the new shoes over to Firestone and get them installed and the alignment completed.
I have been calling it a "her" since the beginning, but last night on the way home (most specifically while climbing/falling out of IT once we arrived home) my GF named it...Sasquatch. :safari-rig:
Mudicon
Beowulf, thanks for the link! Unfortunately the windows for our LJ's (LWB) are discontinued, although I could buy a TJ set, use the rear, and attempt to sell the sides...it's a thought.
Mudicon
Installing a Safari Snorkel - with Rugged Ridge Mirror Relocation kit...
Ok, the laws of physics state that two objects cannot occupy the same physical space. While that is true, it is also exactly what is expected if one wants to relocate the mirrors to the windshield hinge (to run door-less and still have mirrors) and also have a need to run a snorkel. I had both needs.
The concept is to rotate the snorkel installation a couple degrees when drilling the lower mounting holes so instead of coming up along-side the windshield frame, it protrudes slightly to the front of the windshield frame. You will notice the bracket originally designed to screw into the windshield frame is now a couple inches forward and has nothing to which attach the screws.
You can see the forward location and the clearance to the mirror relocation bracket.
Next, you will need bracket material. For me, I wanted something stiff, durable, and preferably powder coated. while wondering the isles of Lowes, what did my eye behold but a for sale by owner real-estate sign frame. Black, power-coated, steel angle iron...perfect.
Using a small angle grinder with a cut-off wheel, I was able to cut the right size piece and shape it to my needs.
Hitting it with a couple coats of Rustoleum X2 primer plus paint in flat black, I was ready to install the new bracket. It attached to the Jeep using two new black M8x1.00 1.5 inch hex-head bolts to replace the ones in the hinge.
Install the mirror...
...and complete.
Couple notes...you have to remove the factory antenna since the molded slot in the snorkel no longer fits the factory antenna location. I relocated to inside the dash behind the airbag, and used a Trail Rated 4x4 medallion to cover the factory hole. Also, make sure your measurements are accurate. When properly installed the factory hard doors are still easy to remove and install and you have the convenience of the mirrors staying on the Jeep. Also easier to stack/store the doors without the mirrors attached.
Mudicon
I was able to pickup a pair of LED/Projector headlights for Sasquatch.
Here is a comparison of the new and original:
Mudicon
Thank you! :sombrero: ...it has been a LOT of fun...spent too much $$$, but hey, it will be worth it when out on the trails. I have a few other accessories ordered, but it is close. About time to get started building my Dinoot trail trailer.
poriggity
Building a trailer for it too!!! Nice!
Mudicon
Yeah, I have already started on a frame and should be ordering my Dinoot J-Series Extended tub this next week...just gotta finish Sasquatch first :smiley_drive:
Mudicon
I have finally added a Warn winch and an LED light bar. Sasquatch is getting close to being finished :wings:
Mudicon
...finally a inauguration trial run...and she performed flawlessly! I know a lot you guys do not like mud...but it was SO much fun!
Houie
