Installing a Safari Snorkel - with Rugged Ridge Mirror Relocation kit...
Ok, the laws of physics state that two objects cannot occupy the same physical space. While that is true, it is also exactly what is expected if one wants to relocate the mirrors to the windshield hinge (to run door-less and still have mirrors) and also have a need to run a snorkel. I had both needs.
The concept is to rotate the snorkel installation a couple degrees when drilling the lower mounting holes so instead of coming up along-side the windshield frame, it protrudes slightly to the front of the windshield frame. You will notice the bracket originally designed to screw into the windshield frame is now a couple inches forward and has nothing to which attach the screws.
You can see the forward location and the clearance to the mirror relocation bracket.
Next, you will need bracket material. For me, I wanted something stiff, durable, and preferably powder coated. while wondering the isles of Lowes, what did my eye behold but a for sale by owner real-estate sign frame. Black, power-coated, steel angle iron...perfect.
Using a small angle grinder with a cut-off wheel, I was able to cut the right size piece and shape it to my needs.
Hitting it with a couple coats of Rustoleum X2 primer plus paint in flat black, I was ready to install the new bracket. It attached to the Jeep using two new black M8x1.00 1.5 inch hex-head bolts to replace the ones in the hinge.
Install the mirror...
...and complete.
Couple notes...you have to remove the factory antenna since the molded slot in the snorkel no longer fits the factory antenna location. I relocated to inside the dash behind the airbag, and used a Trail Rated 4x4 medallion to cover the factory hole. Also, make sure your measurements are accurate. When properly installed the factory hard doors are still easy to remove and install and you have the convenience of the mirrors staying on the Jeep. Also easier to stack/store the doors without the mirrors attached.
