New Camper Build - THE OVERL[h]ANDER
msiminoff
Lots of progress happening this week!
The subframe is complete, rear pivot/winch-mount/hitch is assembled and attached to the truck frame, and the Total Composites floor has been (temporarily) fastened to the subframe for final alignment of the subframe-to-frame mounts & bushings. Lots of measuring and re-measuring going on to make sure that we have proper clearances between the camper box and the cab... So far everything fits exactly as planned.
My hat's off to the crew at Durrance Design for making this look so easy (it isn't!).
msiminoff
Here are a couple more shots of the finished subframe. It is not actually mounted to the truck in these photos, just resting on top of the frame rails. I'll show the details of the pivots and bushings as soon as that assembly complete.
Reuben at DDGO (Durrance Design Group Overland) has done an amazing job with the design, engineering and fabrication of this all-aluminum subframe. I am thrilled with the way the project is coming together so far! Prior to my project, Durrance had been focused primarily on engineering and fabrication for the marine industry; Their projects include elaborate mechanical assemblies, as well as turn-key fabrication of commercial fishing boats. The team's passion for adventure travel has inspired them to expand their service offering to the overloading industry... a wise choice :cool:
In addition to building the subframe, Durrance will be assembling the Total Composites camper box for me, as well as fabricating some pretty aluminum accessories (side boxes, rear deck, ladder, bumpers, etc).
msiminoff
Will the sub-frame be heat treated before assembly?
No. The subframe was engineered with the knowledge that it would not be heat-treated after assembly, and high-load areas are reinforced accordingly. In addition, the welding strategy is designed to minimize the heat affected zone.
Are you planning on plugging all the holes so that your sub-frame does not fill with dirt, dust, and mud?
No, the holes won't be plugged. However the subframe is designed to be flushed out with a hose or pressure washer when necessary and there are weep holes to prevent water accumulation.
Cheers,
-Mark
Santa
Cheers,
-Mark
msiminoff
Do you have measurements of the planned height/length of your cabover?
Here's another drawing with dimensions (in inches) for the cabover portion.
Keep in mind that these are outside dim's... the cabover floor & the ceiling are 3-1/4" (83mm) thick. Walls are 2" (50mm).
Let me know if you need more info.
-Mark
AZXPLOR
