2012 Range Rover HSE Build/ Travel Write Up
Colorofkris
How did the injectors look? I'm having an induction service done on mine Tuesday.
Haven’t pulled them yet, I’ll let you know in the next couple days. Hoping to get to them tomorrow, they have been soaking with pb blaster for just about 24hrs now.
Colorofkris
Injectors came out surprisingly unscathed. They definitely need to be cleaned up though. I’m now just waiting for the new valve cover to come in and the new seals for the injectors. (Should be any day now)
To get to the last injector I had to remove the plastic filter piece that runs from the center of the hood as well as the plastic around the battery tray.
All that being said I’m really looking forward to getting it back on the road!
Colorofkris
I’ve got a good bit of carbon build up on the ends, I plan to give them a good clean before reinstalling.
GSP
Are you sending them to be cleaned? I think injectorRX charges $45 per with new teflon seals for same day turn around.
Colorofkris
No I’m going to hit them with some carb cleaner, I’ve got new seals already in with the new tool to install them. I don’t have the time/ money to send them out right now. I’m going to look into replacing all 8 injectors at the 200k mile mark anyways. Also depending on how the timing chains look when I pop the valve cover off will determine if it going to even keep the range Rover.
GSP
We got the RR back from the BG induction service today. It seems to be running better. It had a strange hesitation at low speed under maintenance throttle. Very slight, probably unnoticeable to someone else.
Colorofkris
The computer is probably relearning everything after the service and resetting the values on all of the sensors. Should sort itself out within 100 miles
Colorofkris
Valve Cover Update-
Finally got the new cover in. I went with the genuine Land Rover cover. Opened up the box and found 2 of the fasteners missing which was awesome. Anyways, I was able to get the old valve cover off.
Checked the timing chains while the cover was off and there is hardly any play at all in the chains which is a huge relief.
Also cleaned up the injectors. Still need to remove the software and reinstall the new software.
Here’s were the fun begins. I found the torque pattern and spec finally, Pic posted below. Turns out that 13 nm is not the correct torque spec, snapped the first bolt! Hurray! No problem, I’ll use and old fastener and just drill and easy out the broken bolt….and then the east out broke off inside the bolt. I really don’t understand why everything has to be so ridiculously difficult on this thing.
So that’s where I am at, frustrated, stuck, and in a constant state of regret buying this thing. I’m going to head to the store and pick up some grinder bits to hopefully grind out the easy out, then re drill the broken bolt and try a different easy to get it out. Looks like I’ll be picking back up Saturday.
gatorgrizz27
You may have to re-drill and tap that hole, I’d check your torque wrench also. According to an online calculator, 13 nM is only 9.5 ft-lbs, I’d have assumed a bolt with a 10mm head would have a torque spec of 10-12 ft lbs. I wouldn’t expect that bolt to break under 25-30 ft-lbs of torque, you might be lucky it didn’t strip the block if the wrench was bad. There are always heli-coils.
I curse the layout of my wife and I’s cars every time I work on them, both have the AJV8’s, which were never designed to fit in there. 3 bolts to remove a part, two come out easy as can be, third one hits the driveshaft backed out halfway. Price to pay for a LR with a reliable engine is what I tell myself…
Colorofkris
Luckily I don’t think it stripped the block. What’s making it difficult is that the east out broke, if it wasn’t for that I don’t think this would be that big of an issue.
Colorofkris
There’s always a welder
That sounds awful lol. I’m hoping it doesn’t get to that point. I’m working on drilling out the broken bolt now and I’m just about there. By the looks of it I’m going to have to go the helicoil route . Because of the broken east the drill didn’t center and walked a bit weird.
J!m
Get a set of left handed drill bits. Use these to drill for the extractor, as the heat and counter-rotation from drilling are often enough to not need the extractor.
And if you break a lot of extractors, you might consider a couple carbide drill bits.
These are a few good videos on broken bolt extraction on YouTube. A lot of old-school techniques documented for future generations.
Colorofkris
I most certainly should have started with the left handed drill bit. In to deep now though. I’ve got a helicoil set coming in today and I need to finish grinding out the rest of the fastener. Hoping to have it patched up by Monday.
  • Like
Reactions: J!m
