1990s MB truck owners. Looking for some details!!
sprocket3
That was the number that the prior owner spent on converting as he bought new Hutchinson aluminum wheels ($1000+ each) and brand-new XZL tires ($1300 each). Along with 80 new wheel half bolts to get the clearance he needed. Add in shipping and labor for someone else building them up for him.
On the other end of the spectrum for spare tires (2) I bought used Aluimum Hutchinson wheels for $125 each (they have to be a specific model not any MRAP wheel works, see this post HERE for what works) and used XZL for $125 (+$125 shipping), so $375 per wheel/tire for spares.
That's more like it! There's usually a cheaper way if you put the work into it.
mog
Kodiak Buckaroo
To put the 'low end' into perspective.
Rims- I had looked for those Hutchinson 'Atlas' rims for almost 3 years with no luck whatsoever. It was only after I sold the truck, with complete luck that a guy 8 miles from me had tons of US military surplus (trucks, trailers, engines, wheels, tires, etc) and I went over just to buy some cheap 20x10 steel rims ($80 for 4) to use as stands for my camper jack and saw those Atlas wheels. He had not even listed them as he only had two and figured no one would want them. So I bought them for the guy that bought my 1017. I would not count on the same luck.
Tires- The military surplus tires are super cheap BUT my friends who have been running those surplus tires have bitten the bullet and paid the crazy price to buy new manufactured ones to replace the surplus ones they had. Too many failures were directed related to the surplus tires age and conditions under which they were stored. Hopefully, infinitely more experienced members like @charlieaarons will chime in on surplus tires.
So the short version, don't use the high end ($10,000+) or low end ($1,500) as your budget. You will want to check ahead if you get a truck from Europe as it might be cheaper and easier to at least get super single rims over there. And you need to decide between 22.5 or 20 inch rims, a whole different story.
And another tidbit for your search. A German friend of mine who worked as an engineer for MAN (in Switzerland) for over 30 years bought a 1995 MB1120 for his 'explore the world truck'. When I asked him why he was a 'traitor' and did not buy a MAN, and the fact he could buy any year truck as he lives in Europe, why a 1995? He said he thought that Mercedes has the best support throughout the world, and 1995 was the last year that Mercedes trucks were all mechanical. YMMV
Joe917
One note on singles.
There is no question the 20" rim is the way to go "off road".
If you plan on driving "bad roads" seriously consider going to the 22.5" rims. There is a large selection of tires available (used in logging and construction) that will give a quieter ride than 20" mil tires and will have far more tread life.
Tires for 20" rims are not available in South America. If SA is on your list go with 22.5" rims.
skjohans
"You will want to check ahead if you get a truck from Europe as it might be cheaper and easier to at least get super single rims over there."
Custom wheels made in Germany:
  • Like
Reactions: mog
Geo.Lander
Also, if you want proper winter compound tires, 22.5 is the only choice!
sprocket3
Do you think i can get Super Singles for these MB truck in the US easily, or should i try to buy those when i get the truck in Germany?
sprocket3
Does anyone here have seat time in an SK truck like an 1835 or similar?
Can the gear ratios be easily changed in the hubs of these like the LMTV? It looks like most have a planetary hub.
DiploStrat
In my experience, not a prayer in the US.
Edited to add: This is for 8 lug wheels. 10 lug might be possible.
I bought Accuride/Kron Prinz rims from: fabian@expeditions-lkw.de Great price and service and the wheels are perfectly round - unlike MRAP and other efforts. Only caveat, he indicates that he can no longer get rims. Ask.
Joe917
Our truck came with singles from the factory, It is the only one I have ever seen with that option. I would get everything you can dealt with in Germany before you ship it.
sprocket3
Are you sure about this? If so, please post up a link to a thread from somewhere legitimate like Steel Soldiers.
How about two links. I talked to a guy who called them Eco Hubs. I honestly didn't look into it a great deal and just assumed it was a different gear set, but i guess they delete the reduction set.
sprocket3
That's what I was thinking, but i want to get the gearing/tire size correct.
Madoxen
I have an 1835 2001 modle and i would not think you would need to mess with the gears as it will sit at 100kph electronically limited. All day up hill down hill it makes no odds . Well down hill u can find ur self doing alot more.
sprocket3
That's good. What sized tires are you running?
I'd love to hear details on engine/trans and MPG you're getting. I've heard 6-12mpg from different sources.
One of the sellers I talked to said his had "high speed gears". Which makes me think they have different gear sets.
Houie
