Today, some progress was made, but it was mostly just chasing my tail and running into problems
 . Most of todays progress was done in ping-pong fashion, bopping between different tasks haha.
First bit of progress was getting what I could done with the steering links. I am waiting on the final TRE before I can cross that off the list. For now, the drag link will hang at the end off a bungee cord.
Next I wanted to get the calipers out of the way. I ordered rebuild kits from the dealership a while back. Well, while starting to clean these, and getting 1 part torn apart, I realized that there was way too much rust to save these. Fortunately, a local Napa had some re-man's in stock, so I sent these as cores with the wife to pick up some new calipers. I'm not too keen on using these, but they'll probably do fine.
I got 1 put on with the fancy PowerStop performance pads and such to start getting an idea on routing the brake line.
Another thing that got done was getting the lower knuckle stud hardware replaced. It went together well, and gives me more confidence that my hunch about Marlin getting a bad batch of hardware being correct.
Unfortunately the next 2 small things I needed to replace, in order to cross this specific line off my list, opened a can of worms.
When I installed these new hub stud kits back in January, I was pretty displeased with the split washers replacing the flat washers like from the factory. So I installed what flat washers I had. When I ordered all the knuckle stud hardware from the dealership, I ordered 2 flat washers for the hub studs(I was short 2). Well, when I went to install those 2 washers this afternoon, and torque them down, the stud stripped before it hit the torque spec.
While I was installing the new knuckle studs, I was wondering if I could trust the hub studs, and it seems like this gives me the answer I needed. However, it's an expensive fix (about $140 through Toyota). So for the 3rd time in less than 24 hours, I hopped online and ordered more crap through my local dealership lol. So for now, I wait on more parts to complete that.
Something else I did today, was dig out the sway bar, clean it, and lay it roughly into place to get the idea mill going for mounting it on the chassis side. It will be tricky to get around the exhaust. At least its in place so I can slowly work the mounts out in my head.
Today didn't feel like I got much done, even though I did make some progress. It just felt like I spun my wheels, and towards the end I was pretty frustrated with everything. So I called it a day early, with hopes that it goes smoothly next time.
