HDJ 80 - evolution from original to….
.... Where is yours located…
Keeno…
…on the left side, vertical on a slider, straight compared to the fridge – for a perfect weight distribution – both around 35 - 40kg. Pics in 2 weeks - the construction is still under process.
…have any photos of the internal structure of the sides?....
Sorry – I don`t have one, maybe next week, I`ll see Marcus next monday. But the structural stability (30 t shear force, 3t vertical force – I don`t know how to say it in english) is given by the frame sandwich combination.
… the latest feature – table arm…
...whats the floorspace dimensions and height?
...effective length behind the front seats: 220cm (+ 40cm raked) / 86,61 inch + 15,75 inch
...overall width: 190cm – 160cm bed / 74,80 inch – 63 inch bed
...height: 125cm (closed), 285cm (open) / 49,21 inch (closed), 112,20 inch (open)
Yeah would make an excellent mobile edit suite, something Ive been toying with, was planning on using a Landrover 130 but this would be nice too.
Frank, thank you
Does anyone know the price of these conversions? Just the body or housings only?
Dave,
I would guesstimate that it's somewhere in the 25k Euro range for just a "box," based on what was said by another fellow much earlier and in a different thread <hint>... I don't think there's any pricing to be found on their site - it's all custom stuff... Maybe you'll need to go there and discuss it with Ralf over a beer ;)
However, there's a cool little link at the bottom of the page that I found and has a lot of photos that might be of interest :
http://hdj80-under-construction.blogspot.com/
Going back to the first posts there are photos from when they cut the body behind the rear doors.
Cheers,
Frank
I have a friend that travels to germany every year quite a bit and is fluent. We're going to find out for sure. . so $25k isn't too bad for what your getting. It would make quite the amazing rig thats for sure.
It sure would be amazing ! You're very fortunate to have a friend to help you there. Will you be shipping your car over for the conversion ? I don't see how they could do it otherwise - it's all custom. Also, the guesstimate is 25k Euros, not dollars... I heard that there's been a slight improvement in the exchange rate, due to the troubles in Greece (?), but generally speaking the it has been costing about US$1.35 or so for one Euro.
Good luck - I sure hope you can do it !
Cheers,
Frank
Hi folks &#8211; after months a little update.
Watertank 100L (cold water)
Waterfiller left side/cold water &#8211; right side/hot water
Sparewheel on slider
...90% is done&#8230;
...paintjob...
...next to do: the final paintjob and some electric wireing ... 2 more weeks ...
tbnd88
