SUCCESS!!! Sort of.
Yesterday I went to PnP again, with a buddy, as he was looking for some parts. They didn't have anything we needed. It's always a good 2 dollars spent to check that place, you never know what you'll find.
Then we decided to go to another junk yard that was over by his house. Last time he had ventured there, they had 1 4Runner, and nothing he needed. They pull the engines and put them in a section of the yard, to make it easier to dismantle the parts off the engines. I wanted to check if they had the EGR temp sensor and the vacuum port. Who knows when you'll score?
Well we get there and ask the guy if they have the 4Runner still, he says "yeah, the blue one in the back and there's the red one out front" My buddy freaks out, because they've had the red one for a while, and nobody said it was available for parts. We pop the hood, and boy are we excited. It's like Christmas morning. The whole truck is intact. Probably a blown headgasket or seized engine from the looks of the inside of the intake manifold. Lots of sludge in there. We go to town, I pull the parts I need, he grabs his relay. We go to the guy and ask him for the prices on the parts.
My buddy's convo goes like this:
"How much for the relay?"
"10 bucks."
"Oh I don't have enough cash I'll have to go to the bank real quick" (cash only)
"5 bucks no warranty, it's on you if it doesn't work"
"I have 4 in my wallet"
"F it, I'll take 4"
And mine?
"I just need this temp sensor and the vacuum port, and I don't have any cash, how much you want I need to go to the bank"
"Uh...10 bucks? Uh-"
"Ok 10 each, I'll go to the bank right now"
BAM! $20 dollars later...the vacuum port and EGR temp sensor are replaced and there is no more CEL! Given that the temp sensor is about $150 and the port about $30, I think I got a pretty good deal
I was thinking about going back and offering for the 5 speed conversion...probably would have been able to get it for no more than $200
Now for the weird part.
Once we replaced the vacuum port and sensor, reset the ecu (pulled the EFI fuse, better than removing the battery cables since you get to save all your radio stations and clock settings) we tried out the 4WD once again. Here's what happens. Put the truck in (N) shift into (H4) and the 4wd light blinks rapidly like it's trying to switch on and then nothing. It's a random number of switching, and it's not a code type blink, as you can hear a relay clicking back and forth.
This started happening after the port was replaced. This leads me to believe the vacuum lines are either clogged, or switched around.
I had traced the lines, (prior to replacing the port) I even found that these were the original lines with the brown/whitish spot on one line, and the blue spot on the other, indicating which VSV they were going to. I believe they were in the wrong spots before, so I had switched them. I believe it was brown to driver, blue to passenger? I have to look again. I'll switch them back again and see if that fixes it, if not, I'm going to replace the vacuum lines to rule that out.
