@Adrifters - F550 Surf Camper Build - Adrift Motorhome
Healeyjet
Scott, you will end up with a very mobile, useable camper. I am sure with the level of thought you have put into it so far it will work out better than ever!
Ward
pappawheely
Autonomous4X4
Building a custom vehicle is not for the weak. I built three different rear suspension designs before I got what I wanted; so I know how it feels. It's better you found the weaknesses while you could revise them easily. Having a failure in the boonies really sucks.
Peterf
Hi. I am extremely interested in your experience with four LA36 units from Linak. I am looking at building a custom pop-up camping trailer and would like your views please, especially on how reliable they have been and the appropriate model. the LA36 may well be huge overkill for my requirements
S2DM
The LA36 has worked well and been reliable. Depending on the weight of your roof, and how much syncing you need when it is going up, they may be overkill, but its nice to have the options. Because my roof is a cabover and I am using motion control slides, I really needed it to go up square.
I have an extra set for sale in the for sale and wanted section at half of what a new set would run. Linak came out with a new control system that I wanted and I ordered the first set with the wrong clevis end for the mounts I'd made, so I decided to buy a new set.
racer3822
Old replies but I figured I'd chime in as I've just gone through a month long balancing process with my tires and they have improved alot!
I ran Dynabeads in my Hutchinsons and it was a nightmare. The rubber Beadlock inside the wheel has two finger sized holes to allow air to pass through them. After not being able to get my wheels to balance, I took them apart and discovered beads had easily fallen into these air holes and were on both sides of the Beadlock, if that makes sense. No way to prevent it and get a decent balance with this design. Not to metion, Dynabeads customer service was absolutely terrible. Just my experience though.
You can solve that by installing 2 air filters into the holes in the beadlocks. Stazworks came up with that solution.
I believe that you can add the beads through the valve stem and not have to split the rim. I'm sure that is not the case for all beads (airsoft bb's will not go through a valve stem) but the ones that are sold for dynamic balancing specially should.
Sent from my SAMSUNG-SM-G890A using Tapatalk
If you are running bead locks you absolutely can't add them this way, they'll get stuck.
What I've been 'told' is that the hutchinson beadlock won't reliably let the beads through the rubber ring and into the outer portion of the rim. But thats not coming from any personal experience, so could very well be wrong.
When I opened up my Stazworks wheels, which are split with the plastic beadlock inside, I had absolutely no beads that got past the beadlock. Most of them were stuck to the tire where they should be actually. I ended up vacuuming them all out!
I guess my concern if how well they work for dynamic imbalance, a bead lock that is constantly changing position. I tried centramatics and am not sure they helped much. If the beadlock is moving, it is also likely not reliably pinching the bead in position during air down maneuvers, so I am hoping to figure out a way to get them tight and stable first off.
I took it down to Nate Jones who did a combo of tire shaving, old school traditional balancing, and then a final balance with the tire on the truck, which balanced the entire wheel and rotor assembly. Its now amazingly smooth. He's really a master.
I was also having alot of irritation with the shimmy at speeds. When driving 10 hours a day it gets on your nerves!
My end solution to help the balancing was to vacuum out all of the beads and take them to a Goodyear truck service center who had a large enough balancer for my tires. I also was concerned about the inner beadlock donut, and was considering splitting the rim and removing it for balancing and then reinstalling marking where the tire and rim was, but I figure that in itself will cause more problems moving things around so I would just balance with them in place and hope they are negligible in how they affect the balancing.
After balancing I also added the centramatics and they seem to do well at nipping the final balancing of the tire. Perhaps they compensate for any movement of the donut?
In the end it still has a little bit of a shimmy at 65mph, but nothing like it used to! I do yearn for the days of 35" completely smooth ride tires at times, but the trade off is worth it now. Perhaps I need to drive to visit Nate Jones, lol. I never even heard of him or that he could take on balancing problems like this!
Healeyjet
Good morning everyone. From what I can tell by the California Fire Map, the fire is very close to Scott's home. By my calculation less than a mile. Sending positive vibes to S2DM in the hopes that the fire stays away!!
Ward and Annie
java
Ward and Annie
Damn, good thoughts headed your way Scott! Hopefully the truck is packed and they are long gone.
Healeyjet
I was in contact with Scott yesterday and he said the fire line was about 1/2 mile from the house and they were safe.
Ward
S2DM
Finally got the rig mostly back together and did a test run this last weekend.
The new coating/color is a combo of Line-x products. The Mercedes blue grey color is Line-x Ultra, which is a lighter weight formulation of the standard version. Weight wise it is better, also UV stable, but its a little softer than I'd like. The black is the standard line-x, topcoated with Ultra for UV stability.
New subframe is steel and very strong, new storage boxes and lockers. I did everything in solidworks and had it sent out for laser cutting, then had a local shop bend it and weld it (my tig skills are pretty so so). Managed to shave almost 2k lbs off the rig also much more rigid now.
New suspension from Deaver has required a little adjustment to get right, but now that its done is really impressive. Good articulation and rides like a caddy at 80mph.
Final weight loaded to the gills is a little over 14k.
Still to come are the outdoor kitchen pullouts. A few images.
uc
uc
uc
uc
uc
uc
S2DM
Here is one with the forward accordion wall all the way down:
uc
uc
and all the way up:
uc
The front wall is powered by a small linear actuator from firgelli and has 18" of travel. When the main roof goes up and down, it passively leaves the front sealed through a series of pulleys and .125" amsteel blue winch line. Using the actuator allows it to lower. To come is a screen attachment for the front so we can leave it open when its buggy out.
CharlieGreenT
