Hi Stu,
andy
youll have to keep us up to date on how the rims and tyres stand up to a bit of a flogging
while im all for polished alloy the crusty old fart in me says nothing handles abuse like good old steel
They are certainly soft and as careful as we could be with the wheel balancer at the local tyre shop we could not help but scuff them on the inner mating surface while doing it which is visible on the back wheels, but I think it would polish out if you were worried about it (I'm not, wont be long before they get exposed to worse stuff than that). I'm sure they wont wear as well as steel, in the end I just could not buy any in steel ones at an 8" width.
We got stuffed around by Eastern Wheel works who was all talk about it being no problem until we ordered and they suddenly began stalling, not returning calls, making excuses etc etc. The trouble was we already had the tyres on the way from the states based on their assurances. None of the other wheel manufacturers we tried (Titan/Andy's, ROH, mullins, Adelaide wheel etc) could build a wheel to the load rating in steel, the issue was there are simply no outer rims available any more. All said ROH were the only ones making them but don't any more. They could all get agricultural rims in the size but they are not approved for highway use (no valley in the middle for instance to keep a flat tyre on the rim at speed as required by ADR). In the end Alan's option was simply the only one to suit the 16" tyres we had bought.
It wont get much work for a couple of months yet until the truck is ready, but when it does i'll report in. I've checked out all the options on whether to clear coat, ceramic coat, powder coat them etc etc but nothing seems ideal. Clear will peal off (even wheel repairers have said it cant be done reliably), ceramic is too dear and not clear, powder coat can be done in clear but the rims need acid etching first which destroys the look with random etch patterns so would need to be silver coat instead. It will be doing a fair bit of beach work so im going to try coating it with lanolin before we leave and cleaning and polishing them on return from trips for a start, at least to see how long till I get sick of polishing them
Once that happens I have the option of sandblasting and the powder coating which was not too bad ($77 per rim).
blackduck said:
i like the idea of 16" wheels just not sure about having to rely on the good old US of A for tyre supplies
especially if the dollar takes a dive
stu
I went for 16s because it had a very nice (beautifully made, very strong) set of Andy's Rims (now Titan) 19.5"s on it when we bought it and it rode terribly (read: backbreaking) on the 19.5 tyres. I've been driving it around on Michelin XL 9.00s while waiting for the rims to come and its a totally different truck, much much softer ride with a forgiving sidewall. Also despite what some may say, having done almost 30 years of beach work in 4x4s and towing vans on the sand also, nothing beats letting the air out and getting a big flat wide long pad to float along on and I just don't think I'll get that out of the narrower, much lower profile, less conforming 19.5s. This is why the XZLs are so good, they have sidewall to balloon, despite being much narrower than the ones I've opted for. I'll confess though, the tread pattern I've opted for is not ideal for sand (a little too aggressive) but they will be ok, I just wanted a go-anywhere tyre this time so this was it.
With regards the US and the inevitable sliding dollar, all of the Australian sourced ones will go through the roof in no time flat anyway if that happens. You'd have to have cash waiting to buy within weeks of a drop before local stocks run out to negate that.
There were also several options in 16s but I could only find one suitable in 19.5" size (the Toyo M608) which seemed a risk to me if they go out of production or get suddenly expensive. If I downrate the truck to 4495kg (which I'll do if I can keep the weight down) I have a dozen tyres to choose from with a 124 rating in 16s. The trucks these are found on in the US are one one of the most common vehicles on earth so supplies wont stop any time soon. The Toyos seem a specialty tyre to me with no great volume to them as is with the 16s, you certainly wont see them on a few million average US pickups.
In any case, to each his own. I'll see how I fare with these and report in. They are a very substantial rim. They were also very light. The steel 16s wit the Michelins on them weighed in at 59.8Kg each, with tyres these weigh in at 42Kg (over 100kg saving over the 6 rims).
Cheers -Andy
