xpdishn
We have just returned from 8 days in Utah and this trip clearly defined several issues that I need to address. When time permits we like to be out that long or longer. On this trip we used 20+ gallons of water and containers are a PITA. We don't have to refuel in that time and we don't want to re-water in that time either. I have done what I thought was an extensive search and have come up with nothing.
A (semi) permanent water storage solution is a must. An in-line 12volt pump and spigot is also on the list. I would think the latter two would be the easier part of this install. (Hopeful thinking) On to details.
I have a '07 FJC. I have taken the rear seats out and have installed a storage platform in their place. The dogs lay/sleep on it, very handy. The front of the storage unit is directly behind the front seats and have room for a custom water storage unit. It could be either a bladder type or hard shell. Plastic would be preferable due to weight, I will be building a protective box around either. I can use the full width of the rig but there is a hump in the middle that would prevent uptake of the water when the level got too low. Trying to figure that out also. As that part of the floor gets pretty hot, I will be insulating the unit from the heat.
The pros for this install are:
1. The elimination of several containers that take up valuable space in the cab where space is a premium.
2. It would move the considerable weight down and to the middle of the vehicle where it belongs.
3. It would be extremely handy and convenient.
So the question goes out: Has anyone installed something like this and where did you source your storage unit? Pros/cons? As the space is irregular in shape I am fully aware that a true custom design is in order.
I have found All-Right Holding Tanks web site, but any further help would be appreciated.
Thanks in advance,
Gary
Thanks in advance,
Gary
