CVT Group Buy!
latybug
Jeff, you're going to love it! I have a Shasta and it's awesome.
Blackdawg is right, there aren't any fitted sheets that are the right dimensions. The width is not an issue, but even the California king size ones are a few inches short for length.
My solution:
I took a queen size flat sheet, tucked it under the edges, and secured with safety pins under the corners. Works great! :)
LOVING MINE!! :D
for those of you think that this will limit your trails..think again..
Nice taco dude!! looks like it deffinetly gets it! Just curious about what material your rack is made of? picking up a CVT this spring, and i've got a square HSS rack similar to that built outta 1 1/2" and was worried about the u-bolts not being long enough.
cheers
Lumpy
Blackdawg
Dr. Frankenstein
cheers
Lumpy
Thanks man. Its changed a bit since those pics. Ive added a roof section and lots of lights. Still love the tent :D im adding lights to the inside of the tent and outside for the ladder for convenience. I no longer require a flash light to set up camp :D
'But yes..i do use it! can't wait for spring to get out again.
anyways, yes mine is 1.5'' square tubing that is 1/8'' thick. It is the absolute MAX for the bolts on the RTT. Otherwise you would have to get your own. But they do fit.
skates04
CVT confirmed on ih8mud they will be doing another group buy in March:) They also stated they will have several new releases on the 1st.
See post #10 on the link to ih8mud
Link
vertical.dan
