Scott
Thanks for your perspective
Where did you place the heater to ensure it didnt burn anything and did you run it while your sleeping? Did you think there was more ventalation with this tent?
On adding more material, can you tell me more about that?
Thanks
As you can see from the attached photo, I used a hole saw cutter and and ran the exhaust & combustion lines out through it. Espar calls out a separation of at least 8" between the two and I have something like 14", but they also are pointed at different angles so the chances of sucking in exhaust into the combustion is not a concern, and my cold air intake is coming in through the other side of the rocket box, well away from the exhaust. I only use the heater in the evening and getting up on cold mornings, I have a Marmot down bag, that keeps me warm down to 0F, and lower than that I have sleep with my down coat, etc. I will get a good test this January in Mammoth as I like to go wolf watching in YNP and that is about as cold as it gets in the lower 48.
Not too much to add on the material. The canvas guy I used also makes wall tents, and he had some coated material he uses on the bottom of his wall tents so that it doesn't mold or mildew. He just sewed on an additional 10" strip all along the bottom on all the panels. Just wanted something when all hell breaks loose to not only stake out the panels, but to place rocks on when the wind really howls, which seems to be every time a go out camping.
I always thought any of the EA tents vent real well, lots of openings to let air in.
Replying to the other question about fore/aft centering, it really isn't too bad. I have mine extending up just past the water tank, and in the rear it goes about 13" past the end of the trailer. Don't have a problem at all with the forward placement and the rear isn't too bad, but you could possibly hit your head back there, though with the tail gate down this wouldn't be a concern.
I didn't have to move my vertical supports for the Fiammia awning. I just took them Partner Steel and they cut about 3 or 4" off the top (I hate cutting SS), and I have about 2" gap from the tent and the supports.
Hope this helps,
Scotty
