Scott Brady
Founder
Yes
about 3 tons.... :chowtime:
p1michaud said:Scott,
I was just reading your install article for your Demello Sliders and had a question about the forward mounting point. In your article you said the following: "The image here shows the drivers side frame rail, and the forward most mounting hole location. The holes in the frame are already in place (stamped at the factory), but a bolt cannot be passed all the way through to the inner frame rail side due to the cross-member. You will need to drill a 1/2" hole in the cross-member, properly aligned to the frame holes."
I was wondering if you could post a pic of the backing plate and bolt once it's installed. Did you simply let the backing plate lay at an angle on the cross member? See this picture.
Cheers :beer:,
P
expeditionswest said:Question from Rob:
Thanks for the question Rob:
I am using the following parts:
Thule Parts-
Thule Hull-a-Port Kayak Rack (835)
Thule QuickDraw Ratcheting boat straps (855)
Thule Aero Foot (400)
Thule Cable Lock (538)
Thule 58" Load Bars (LB58)
Thule Fit Kit (111)
Con-Ferr Parts-
6" Portal Rack, Fully welded 3'x5'
The Con-Ferr rack is bolted directly to the Thule Load Bars with 5/16"x1 1/4" bolts. This picture shows the mounting a little closer. This picture shows the rack from underneath.
The Con-Ferr rack has a base mount rail which is predrilled to accept at least 8 positions.
More information and pictures:
With awning
Willman said:Hey Scott!!!
With your current on-board air system with your compressor and air tank....How long does it take to air up one tire from the lowest PSI you go..if i remember right.... about 15 to 18 PSI or so???
Thanks!!!
:costumed-smiley-007
expeditionswest said:Factory air filters only and I carry a spare. No engine modifications at all.
Just my opinion of building an expedition rig. Leave the stuff that could have you stranded alone.
