jeepmedic46
Congratulations on your purchase, Good times await you.
something like this??Default
Ive been wanting to get working on a platform for the rear of my Jeep, for storage under, and a sleeping surface on top.
I have been kicking around a similar design for storage and a sleeping platform. I have thought about doing the same with the 2 door seats and extending the platform but have thought about making only one side be able to do this or at least have the option of only using one side at a time. Not like it would really help but having a little more room to move around and rummage through the storage below the platform would be nice, or at least i am thinking so.
I plan on installing a cage on my XJ so I would support the front of the platform using the B pillars, what have you came up with? Possibly some folding or hinged legs or something similar would work best, apposed to boxing in the front with plywood ect. This way you could fold it all back on the rear cargo area portion.
What material and thickness will you be using? In every attempt to keep my jeep as light as possible modifications such as these do not help![]()
It's great to see so many XJ owners helping each other!
Since I rarely take passangers and if I do it is only one, I wanted to maximize storage and sleep space, so I removed the rear seat completely and then added a deck that matched the level of the rear storage compartment. This gave me room for my 2nd battery and other odd and end that I take along. I am 6' 4" and simply slide the passanger seat forward stuff the foot hole with something and I have enough space to sleep and close the hatch if needed.
Before the most recent modifications I ran BFG 31x10.50 with very good results. I had a 3" lift at the time and with lockers went just about anywhere I wanted. The XJ can really flex and see in this photo:
Great job so far on your XJ and thanks for sharing with us all.
Thanks,
Fred
Explorer 1
So today I started my next modification. Im making quick-disconnect mudflaps for all four wheels. I personally love the look of mudflaps on a rig, and you cant hate the functionality. My tires stick out a bit past the fender flares, so I get mud and rocks flying up into the sides of the XJ all the time. The other day I was riding windows down on a wet gravel road and got all kinds of mud slung inside, so Im going to do something about it. I just purchased a pair of 18"x24" tractor trailer mudflaps for $30 shipped. Each one will be cut in half for 4 flaps total. This was an incredibly cheaper way of going about it, as big mudflaps are pretty pricey. The rest of the hardware I found laying around my fathers shop. So once the flaps get here, Ill try to do a small write up on their construction. A couple of things I had to get around: I had to work around the rear leaf springs which was kind of a pain, but I think I remedied this; XJ wheel wells are kind of small, even with 31's, and I have to keep the flaps from rubbing when the hang straight down; little hitch pins for the "quick release" are expensive and I need 8, but I dont know what Im going to do about this...either bite the bullet or figure something out. Ive already got all the measurements, and Ill update when I start.
Not just yet. Money is a little tight at the moment, so Im working on smaller things here and there. Unfortunately, the widths and lengths of the rear platform tops are too long to be ripped from one 4' x 8' sheet of plywood which means Im going to have to get two sheets just to make it. I want to carpet it all also, so Ill have purchase that, along with hinges and other odds and ends. But as soon as I can get enough together to do it all at once, Ill definitely post it up.
