ntsqd said:
I've logged something in the range of 10,000 miles flat towing my 'glas buggy. With that vehicle in flat tow you can not back up.
No idea if this is true with a 4rnnr or not, but I suggest finding out b4 heading off.
A few thoughts:
Don't worry about the ADD, it is made to do what you are doing...driving around without power to the front wheels.
Disconnect the driveshaft, as the transfer case pumps from the input shaft, as mentioned above. (AFAIK)
Regarding backing up...because of front suspension caster settings, you should NOT attempt backing up with a flat-towed vehicle. I can be done in theory, and I'm sure someone can profess to accomplishing this feat, but please do not try it. BTW, the lighter the front end, the harder it is to do.
With the rear driveshaft disconnected, transmission should be in park, transfer case in 2Hi. This keeps the driveshaft from twisting up whatever you are supporting it with. (Assuming it is not removed completely...can you do this on your truck?)
Turn to ACC and unlock steering, for reasons mentioned in above posts.
If you have a set of old tires and rims in good shape to put on the front, the same size as the rear, you may want to change them for a long haul. Flat towing is hard on front tires.
