Here's a brief history of the problems Michel has experienced with
the connection between camper and truck chassis, as described in
Michel's bolg.
Chip Haven
Michel's camper is built on a steel subframe. The subframe is attached to the truck chassis at three points. The right and left front corners are bolted to the chassis. A third point at the rear pivots on a bushing. Two shock absorbers connect the chassis rails to the subframe near the rear bumper. The shocks help control the side to side rocking motion of the subframe around the pivot.
When the camper was first constructed, two square tubes are welded to the sides of the subframe near the front of the camper. The tubes extend downwards, and are bolted to the truck chassis. Two bolts are used on each side. The bolts pass horizontally through a hole in the wall of the tube, and through an existing hole in the truck frame. A nut on the inside of the truck frame draws the assembly tight together.
The subframe does not rest on the truck chassis. The weight of the camper is carried exclusively on the two sets of bolts in the front, and on the pivot bushing in the rear.
After 3 months of service, including many miles on the roads of Baja California, the bolts failed.
Read about the problem here
http://michelszulckrzyzanowski.blogspot.com/2007/06/failing-fuso-santek.html
And read about the repair here
http://michelszulckrzyzanowski.blogspot.com/2007/06/failing-fuso-santek-2.html
In August 2007, Michel returned to Santek Campers, the company that built the camper. At this time, the connection between sub-frame and truck chassis was changed. In place of the vertical square tubes and bolts described above, a steel bar was welded on each side under the subframe. These bars were attached to the truck chassis using a pair of U-bolts on each side.
http://michelszulckrzyzanowski.blogspot.com/2007/08/flying-forewards.html
The metal-to-metal contact between the bar and the truck chassis made scraping sounds when the subframe pivots. So, a few months later, Michel had a mechanic in Baja insert a thick piece of rubber between the bar and truck chassis. This eliminated the noise.
In July of 2008, Michel noticed that the truck was tilting. The explanation offered by several mechanics was that the truck was heavier on one side, and the springs on that side had sagged. The solution was to remove and re-arch the springs.
Michel thought that a bad crash over an unseen speed bump a few weeks ago might have played a role in the problem.
http://michelszulckrzyzanowski.blogspot.com/2008/07/why-is-she-tilting.html
The re-arching of the springs helped, but the problem returned by March 2009. This time the mechanics spotted the damaged truck chassis.
