97heavyweight
Roof panel installed. This is the reason why I eventually narrowed the camper to 60". I was able to find these ACM sheets in a 5'x10' sheet and it gave me the option to have a solid roof.
Thanks! It wasn't to hard to do. I did have a bit of a learning curve at first and the R&D portion was rough.Awesome. I love this. I also can’t weld, but have considered something similar from pultruded fiberglass tubes and sheet... it’s been in my brain for years, but never had the cajones... My hat is off to you!
great yes. fast no. i've been using 80/20.netdid you find a good source for the 1" 80/20?
Recpro makes an RV siding that comes in a 10' wide roll and up to 50' long or so. I was going to go that route but decided to not worry about attaching it to a sub-board and then paint.I started my own build and taught myself to weld. All was going well until I decided to change my design and enlarge my camper to a slide in. Now things are going much slower but I am close to the end of the framing. I am thinking about using ACM as well but lately have been thinking more about just aluminum sheet if I can find it in a roll that is 5' wide. My camper is 12' long and it would be great to have one piece on the sides. I did find 6' X 13' galvalume. I guess I could just use that with a wrap given it is not painted.
Yours is looking great by the way. I love the simplicity and how fast you are moving on it.
Hello, yes it certainly can be done.I first saw 80/20 at an OEX down in Amado, AZ (long ago ?). It was being used for interior cabinet framing in Bryan Bass’ archeology van. Some random guy next to me mumbled “bet you could use that stuff to build your own camper.” Now I’ve seen it! I’ve been toying with the idea of building a simple canopy out of wood framing (project plans galore) but this throws a curveball at me. Great build.
A couple of questions:
How do you plan to seal the camper to the truck bed rails?
I see a crossmember(s) running across the width of the bed towards the back. Is that for temporary bracing while you’re working on it?
I see you’re using typical clamps on the bed rails, much like fiberglass canopies. I’m sure you have additional plans but a cautionary note: the clamps allow for needed flex when offroad but on sustained washboard the camper may “walk itself back” if not pinned through the bed rails with a couple of bolts both sides. Don’t ask me how I know...?
Following with great interest!
