McCool's basic trailer build
Mccool
I finished a few details in anticipation of our upcoming trip. I mounted my old gas can with a smittybilt mount. I also mounted an axe and shovel with quick fists. And I added some led mood lighting under the tent.
Mccool
Here are a few pics from our trip. 50 miles of beach driving plus 600 to get down here. Camping was a nightmare, more mosquitos than I've ever seen and 3000% humidity. Trailer is working great, though my tailgate lock/latch wasn't up to the challenge. Using a ratchet strap until we get home and I can source I new latch.20180705_202110.jpg20180705_202159.jpg20180705_202143.jpg20180705_202012.jpg20180705_202059.jpg
Mccool
I finally have an update after a busy few weeks. The trip was a success. I have about 2000 miles on the trailer and I'm happy with its performance.
I took it up to my old employer who sand blasted it for me and I put a coat of zinc primer on the body. Hopefully I can finish up the paint in the next couple weeks. 20180806_175417.jpg20180806_183107.jpg
46flattie
Your comment on "stretched the fenders"....looks like you cut a few slits in the back side of the "knee" on the flange to allow them to open up a little and re-welded the flange? Great idea to get a little rather than cut and section. Nice build.
Mccool
Yes, that's exactly right. 3 slits per "knee", 12 total slits per fender. Allowed me to open the bottom up about 3 inches and then rewelded. Took all of 30 minutes instead of a full day sectioning the fenders in a traditional manner.
Thanks!
Mccool
I'm getting around to starting the electrical system. We are headed out next week and I decided to buy a 12v fridge.
I'm using two gc2 golf cart batteries run in series. This gives me 12v and 210ah. I built a tray to house the batteries in the tongue box and keep them secure. Between the tongue box and main box I'm using a couple of grommets with a piece of flexible hose to run the wires through.
The fridge is temporarily strapped down and wired directly to the batteries. This will change once we get back but I dont have time to install everything permanently before leaving.
I'm researching solar components now, hopefully I'll start that process in the next month or two.
502752502753502754502755502756
Mccool
I'm continuing work on the electrical system. I purchased a blue sea systems 12 output fuse block and this fancy switch panel from amazon. I have the panel mounted and am starting on the wiring. Hopefully dirt/water wont be an issue with it mounted outside.
All terminals are being crimped, tinned, and heat shrinked.
506319506320506349506350
Mccool
Anyone have opinions on running the fridge through a rocket switch? I cant see any benefit to it, I'm thinking I'll just wire it directly to the fuse block.
I also need to work out a hookup for "shore power". I've planned on solar, but with just the fridge and some led lights, the batteries are lasting 10 to 12 days. I dont see us being away from power for that long unfortunately, so the solar setup isnt a high priority for me at this point.
Mccool
Unfortunately the batteries added alot of tongue weight. I was planning on a water tank up front, but that's clearly not going to work. My plan now is to mount the water tank under the floor, directly above the axle. Hopefully I can make that work. I'm also going to need to mount a spare tire on the back, I'm hoping that balances out the batteries.
Houie
