So a little update on the '42.
Still was running poorly, so before I spent the money on a carb rebuild kit, I figured that I would pull it apart, see what I have to work with, and clean the living ******* out of it.
The carb and linkages came off easy enough
All apart! I was very surprised by the amount of tiny little pins and springs that make this carb work.
The float bowl was
full of crud that had built up over the years!
Grrrrrrr....... 99% back together.... One little spring leftover. I hate that!!
Ok. Once I found the home to that spring, it was all done!!
Then I set about hooking up all the linkages and bolting the carb back on.
It fired right off, and I grabbed a screwdriver and then I was able to dial it in perfectly!!
Also, we recently went back to ND for a wedding, and, in the Subway parking lot, there sat either a '58, '59, or '60
Wide-Window Dodge Power Wagon! Super cool and pretty rare!
