My Landcruiser Odyssey
cruiseroutfit
Its a true road warrior.
Tim dropped me off at the bike store (thanks again Tim!) and I rode with the owner over to his house to grab the 60. We handled the paperwork, exchanged some cash and I was on my way. She fired right up, just as he explained it has a "miss" at lower rpm's, though as soon as it hits ~1500 it really runs great. I go to push in the clutch and shift it into first... grrrrrnd. Clutch isn't fully dissengaging. Pump it a second time and I can feel it pump up and dissengage. Easy, I just need to rememeber to double pump it each time. I check out the gas gauge as I drive back towards Main Street, everything in check but the gas gauge. I figure I better top it off, check the fluids and go from there. As the pump filled I systematically checked the fluids under the hood. The oil was a tad low, nothing to worry about but with a long drive home I decided I would top it off. The PS fluid was full to my amazement (it drove like it had manual steering). The radiator was full, and the brake and clutch mastes were good to go. I finished topping off the tank, grabbed a Mtn. Dew and I was off. Just me and the Cyprus Hill cd the owner had left in the CD player... "insane in the membrain"... yeah it sucked.
She motored down Main Street just as expected, a little rough off the line but nice and smooth as she roared into the upper rpm's. By the time I reached the highway speeds north of town I was confident it was going to be a smooth ride home, I could actuall pass on the flats and hold speed on the hills, something I havn't done in a Land Cruiser of mine for quite some time (take not I havn't owned a Land Cruiser with 30" tires in some time either). I reached the intersection with Interstate 70 in what felt like minutes after leaving Moab, she was a race car. To celebrate I bought the two of us a bag of jerky from a roadside vendor and again sped down the road, this time heading west on the 70. I thought it prudent to top of the tank in Green River, at least that would give me some sort of inclination as to how the vehicle was running fuel wise and where I would need to stop again for fuel if needed. To my amazement I had only burned ~3 gallons from Moab to Green River, a distance of ~55 miles, meaning even at my above average speeds, I was getting 15+ mpg. At that rate I should be clear to drive it home on the tank. With that peave of mind, it was back to the interstate. As I approached the interchange heading to Wellington, I couldn't help but think of the lonely swell, just a couple of miles further down the interstate. I've got a rig that runs great, a clutch that has to double pump, an unknown condition 4WD system, a bag of beef jerky and a 9mm... I did was I thought was best... go wheeling.
I entered the swell via Black Dragon Canyon. The canyon bottom is strewn with bowling ball size rocks, in combination with the low clearance and the crappy power steering (it was tight, just not much power), I decided it was already time for low range. "Click" it slid right in, and the light on the dash lit up "4WD". I wasn't too concerned with having true 4WD, if it got bad enough I would get out and lock the hubs (hmmm, had I ever checked those back in town?). We motored up the canyon, passing a couple of hikers along the way (I turned down the Cyprus Hill each time I encountered anyone ;)). The one obstacle I feared was nearing, its a 2 foot rock ledge, with sand making its base and top, nothing to precarious for a normal rig, but this thing sits low. I gave it the college try, attempting it in 2WD low just for giggles. The front end popped right up, but it quickly snagged the front diff once on top, we were stopped dead in our tracks. I got out to survey the situation and more importantly lock the hubs. Passenger side first... "click", good to go. Drivers side... nothing. It was seized in place, and no amount of force I inflicted with my hand was changing that. Oh well, no sense breaking out the tools for one little obstacle right? I got back in the 60, fired her to life and backed it down a couple of feet. From there I gave it the "Moab Bump", and with a bit of tire squeel and alot of dust, she made it up. Victory was mine.
The remaining trip would take me through the ************** Benches and up Buckhorn Wash. The truck was an absolute blast to rally, 50-60 mph hour the whole way, Tokyo drifting around corners. What a riot! We finally landed back on the pavement in Lawrence, just south of Price. The rest of the drive was rather bland considering the adventures thusfar, up and over the summit into Spanish Fork where I topped off the tank again, and on home to Sandy. Mission complete!
Now the rig itself. I'm not sure what her destiny may be. Its a legitimatly no rust rig, the frame is clean and appears straight, no pitting or nasty rot that you see in SLC rigs. It spent its life somewhere in the southeast before coming to Moab with a stop in New Mexico for a handful of years. The interior is pretty beat, not unrepairable, but beat. A good cleansing would actually make it feel usable. The drivetrain seems solid, short of the clutch master/slave issue (easy fix) and the front hub issue (again easy fix) its a sound rig, although I do need to figure out whats up with the power-steering system. Worst case is a bad pump or box, both of which I have spares for. All the exterior lights work, wipers, horn, etc. The only issues I've noted so far are a fuel gauge that doesn't work, and a couple of the dash lights are burned out. Nothing a little elbow grease won't fix. The body has a few dings and dents, the most concerning being on the roof where it looks like he tossed a bike or two arond up there. Nothing that couldn't be fixed (or overlooked). I'm going to keep my eyes out for a truly pristine 60 Series for my diesel build... if nothing sparks my eye in the coming months, I'll build this one, otherwise my FIL is alrady offering me cash (though he thinks the miles I put on it have depreciated it a few hundered ;)) and I don't think it would be a hard rig to find a home for here in the valley. It runs (motor was rebuilt ~30k ago), it has a brand new (1-2years) OEM carb on it (dude paid $900 for that :eek:) and the body has no rust. It would make a great builder/DD for someone, we'll see if its me :D
Pics:
In all her glory:
Race car:
Black Dragon TH:
The ledge:
The cairns along the way:
kcowyo
ExPo Original
Nice Kurt, congratulations - :clapsmile
I know you like those blue 'Cruisers. It must be agonizing right now for you to walk out to your driveway and decide which cool Toy you're gonna drive today.
Starscream
:clapsmile Congrats! You'll both love your 60's. I've never had a vehicle before that brings me the happiness my 60 brings me. Sure, it leaks a bit, it's slow, has no radio, and noisy but there is something that makes them so fun to own!
kcowyo
ExPo Original
More 'Cruiser karma... a true story -
Over the years while I was searching and fawning over the 60 & 62 series Landcruisers, I amassed a rather large picture folder of photos that I kiped from all over the 'net. It's full of 60's, 62's and BJ60's. Some are action pics, some are poser shots, some are driveway scenes. Blue ones, tan ones, white ones, two tones... they are all represented.
One of my favorites was of a tan 60 with a blacked out grill. I only had one small picture of it, but man was it a looker. More than any other 60, that tan one lured me away from the square headlights and EFI of the 62's. I could live with another carb'd vehicle if only I could have one that spoke to me like that tan 60.
Here's the pic -
Other than the Mud watermark, I had no idea where I got the pic from. I just knew I liked that 60, a lot, and I hoped one day maybe I could have one like it. The tan paint and the stance really did it for me. I always wished I had another picture of it in my file. Occasionally I would run that folder as a slide-show for my screen saver and I always enjoyed seeing that pic when it rotated through.
Now I have a tan 60 of my own. Recently while skipping through my LC picture file, I came across that pic again. I showed it to my ladyfriend and told her that one obscure photo was the inspiration for my new 60. She commented how similar it looked to mine and I pointed out the stock mirrors in that photo as the only difference between them. Clearly I had gotten lucky to find one so similar.
Earning street cred -
So a day or two ago I'm scanning the 60 registry on Mud. I still love to look at pics, old habits die hard. There haven't been many new ones added lately so I started back at the beginning of the thread. Now I've heard of "Cruiser karma", but this next part really kinda freaked me out.
On page 3 of the 30 page registry, is a post with that photo of the 60 that I liked so much. Initially my reaction was, "Cool, that must be where I grabbed that pic from". Then I see the owner's sig line -
'87 Turbo Runner
I miss my 60....
You with me?
I look at the avatar and member's call sign and sure enough, they're the same as in the classified ad where I first spotted mine for sale on Mud. I double check the FS ad where I found mine and it's the same guy, same tan 60. The previous owner posted that photo on the Mud registry 3 years ago. I have been lusting after it for a good two years myself. His photo has come across my screen countless times and it always got the same envious reaction from me. It's been my favorite 60 of all of the pics I have saved. And now it's mine, all mine and I didn't even realize it.
The FJ60 this weekend -
I had no idea where that Cruiser 'lived', who owned it or anything about it really. Yet some how, some way, that Cruiser and I have wound up together. I have a favorite quote that says when you have an interest in something, that interest will gravitate towards you. I'm a believer. A total believer. For no logical reason other than Cruiser karma, one random photo that I've stared at 100 times has led me to the tan 60 that I really, really liked. Those of you who know me, know I'm not the type to get all school-boy giddy and geek out for silly stuff. But this revelation has had me geeked for two days.
Now if you'll excuse me, I need to go stare at my favorite picture of Eva Mendes, you know, just in case..... :REExeSquatsHL1:
Moody
Needs to get out more
Wow...the stars aligned, the moon was just right, and blam! You have your cruiser. Very, very, cool.
You scored a nice pistol there...
articulate
. . . now it's mine, all mine and I . . . I need to go stare at my favorite picture of Eva Mendes
Excellent story, and I had a suspicion of where that was going. All the cool stuff happens to you.
Anyway, regarding the lovely Mendes, good luck with that one. I'm pulling for you.
:REOutArchery02:
ntsqd
Heretic Car Camper
Dang, dang, dang!
When I read stories like these my 60-Envy really kicks in.
I had a 60 in my sights. Was mod'd more than I really needed, but would've worked out as they were all well thought out & tastefully executed mods. As the seller & I were trying to arrange a look-see he emailed me that a guy stationed in Iraq had sent him the money. It was gone. Just like that, My 60, gone.
Kurt, if your blue'n isn't speaking to you in that special language we all know then we should talk. I have a good home and a pair of very nice blue Corbeau VX2000's waiting for it. If it is speaking that language then I'm equally envious of both you and KC.
God, give me patience, Right now!
KC, Thank you for those last pics. They reminded me of learning to drive grandad's 292 T-Bird powered '51 Ford F-1.
kcowyo
ExPo Original
"There's a magical tie to the land of our home, which the heart cannot break, though the footsteps may roam." - Eliza Cook
I don't live here by accident. Wyoming is a place where I have wanted to live since I was a child, when I first read about it in books. My first visit was right after college when I flopped in a house in Jackson Hole with 4 other guys for a summer. We paid way too much in rent, drank like drunks, fished and rafted all day and washed dishes for beer money at night. A dubious, if not formal introduction to the Cowboy State.
Not long after, I took a job on a guest ranch in Cody. I returned to the ranch for the next few summers, working with the horses and chatting up the waitresses. One day I left Wyoming. I moved down south to Colorado, got married and started a family. But when it was time to settle down and raise my family, I returned to Wyoming. I returned here to raise my children, to live near Yellowstone, to snowmobile, for the solitude of the desert and mountains. It was my home before I got here and it always will be.
A big part of the appeal to acquiring the Landcruiser was to reestablish my relationship with Wyoming. A truck and camper had encouraged me to travel to states near and far over the last couple of years. Time spent in Colorado, Utah, Montana, Idaho and California meant I had neglected the nearby desert and the mountains looming overhead. The Landcruiser was going to bring me back home.
Getting back out there....
Shield Motif Petroglyphs....
High above the Wind River Basin....
With good weather and good fortune on my side, I recently chose to visit a few local favorite hideaways and to scout out some nearby areas that I had neglected for too long. Castle Gardens provided a remote oasis on a windswept prarie for myself and the many Indians who left their mark here on the smooth cliff walls. Castle Gardens is not an easy place to find, nor to get to. It's not an easy place to leave either.
We found other hard to leave areas too. Before it was all over, we would climb Black Mountain, cross the historic Wind River, pass through the endless desert and sit by a lake.
The day would conclude on a secluded beach near Boysen Reservoir. Water is a precious commodity out here. I'll take it wherever I can find it. A steak burrito and an A&W Root Beer serve as dinner while the receeding sun painted the sky with one of those big sky sunsets. It was a good day to be roaming in Wyoming.
Soft sand....
Dinner with a view....
Cruising the coast....
Sunset on Boysen....
DaktariEd
2005, 2006 Tech Course Champion: Expedition Trophy
Wow, KC!
I'm not sure how I missed this thread until now.
What a great story, great family, great vehicle, great state....geez, this is just all great!
Congratulations! :wings:
One of these days I'd like to get back to Wyoming.
Explored a little in my VW bug back in college, but never any serious back roads. Just need to find the time and get some directions....
Hltoppr
El Gringo Spectacular!
It's hard to be in an office reading that! Makes me want to get out...anywhere...again!
-H- :safari-rig:
kcowyo
ExPo Original
Me too....:oops:
Here's one for ya' Hltoppr. I took this photo after being inspired by a photo you took recently while 'down south.' It's not Mexico, but it will have to do for now.
The Wind River begins in the Wind River Range and flows southeast across the Shoshone Basin. It's the main source of water and irrigation for the local Indian reservation, nearby towns and the numerous cattle ranches in the basin area. Every two and four legged soul in this area depends upon the river for survival. The Wind River is also where nature has drawn the line between the Wind River Mountains and the high country desert region.
Crossing the Wind River....
durango_60
I truly think you are just antogonizing me due to my 60 series withdrawals. I should really buy that 62, marital bliss be damned!
Goldenbora
