Project: Doitall Dodge
Metcalf
Thanks, I am trying to keep it going. My old '42 willys is getting total rehash so if you need build fix you might check that one out too :)
The DoItAll will probably never be 'done', if you run out of ideas to improve it it's for sale right......
Metcalf
I have a lead on a replacement set of tires by San Bernardino, Ca. Is anyone in that area watching this thread, love the build, and want to help me? I need someone to pick up the tires and help with the shipping back to Colorado. I can pay for the help....
Thank you.
Metcalf
Thank you. I will try and keep some new stuff coming to keep everyone entertained......
Its warm enough to paint again so I can finish up the doors and cowl. I do have to say that the amount of solid color is a little overwhelming. I might have to break it up some black rockers, hood blister, or something.
enafzige
I just saw this thread today for the first!! I skimmed through the 40 pages quickly, so forgive me if I missed it.
Are you looking for another set of 325/85/16 Michelin XMLs? If so, there's a guy near Atlanta that has a few sets right now for $795.
Great build!!! --Eric
Metcalf
Hi Aaron! have you been watching the thread the whole time?
I might have found a set cheaper and closer.
I'll keep it in mind, thanks for the offer.
Metcalf
I had a few minutes in the shop the other day....
I made a new PTO cover with a raised angled fill port for the transmission. I have had really good luck ( knock on wood ) with the Getrag 5-spd since I started overfilling it a little bit. Its always been a pain to overfill since there is really no port to do so. I had been pulling the top most bolt on the PTO cover and using a small hose and pump to inject the fluid. Generally this has always been a pain in the rear. The Getrag uses thin motor oil weight fluids so just pouring it in from a quart container is an option.
I traced the PTO cover from my SM420 that is going into my Willys as a pattern onto some scrap 3/8" aluminum. Then I cut it out on the band saw and rounded the corners with a belt sander.
I then drilled the 6 mounting holes and test fit it on the SM420 to make sure everything lined up correctly. I added a large fill port towards the top with a 45 degree fitting and plug. The idea is that I can use a funnel or pour quart sized containers right in the top. For a level, if you pull the left top side mounting bolt ( when looking at the cover on the truck) that seems to be just about the 4.5-5 quart level on my truck.
Just a simple improvement.....
I'll get it on the truck soon. I need to pick up another PTO cover gasket.
bftank
when i had my nv5600 i just pulled the shifter to fill it. don't know how that would work with the getrag though. i always like the idea of having a sight tube to see what the oil level was at like on the atlas transfercases.
Metcalf
I had thought about adding a sight tube. I even bought some fittings and stuff at the store one day that are still in a bag in the truck. The only thing I don't like about the sight tube is that it adds a failure point to the transmission.
It would be just my luck that a stick would bounce up in there and rip the tube off the transmission. All the oil would dribble out without me noticing. Then the transmission frys when I get back on the highway....
I decided to just keep it really simple.
I have read about pulling the shifter out. I never tried doing it that way.
I want to make a little screw on funnel for the fill port out of some pipe fittings. Then I can fill with one hand really easy. Pulling the upper left bolt is about perfect for the level of the fluid. Simple Simple.
Metcalf
100,000 views! Holy cow. I upgraded my photobucket to pro to keep the pictures live all the time.
Cards81fan
Osage Hilltopper
Yessir! This is absolutely my favorite build on ExPo. Can't really articulate why, aside from the fact I just love a old truck, and I like Diesel. So this one really fits the bill!
:26_7_2:
DanoWall
