Project Microtrac
Ok guys, i`m building the Quadrotrac for several years now, and i can`t see when i`ll finish it. So i decided i need something simple just to drive around. Since i can`t use the Motodog any more i found a victim pretty fast :
The idea is to build a little tractor like thing, really easy and without rocket science, so there`s a chance to actually finish it. First mockup:
Cut everything off that i don`t need anymore:
Here`s the secand transmission that`ll go in. This gives me 18 forward and 6 reverse gears:
Here`s the input shaft:
Turned a flange with a register for the sprocket:
Flipped it around and turned a register for the input flange:
Transfered the holes:
Put it together nice and tight:
And welded it on:
The output sprocket is really beaten up, but i need the inner splined section. Btw. i know that the case is cracked. Someone repaired it a long time ago and it wirked fine since then. Since i said no rocket science i`ll leave it just like it is. Wait, maybe i`ll run some beads over the crack...:
It`s hardened so i put it in the oven to anneal it. :
Then i mocked up the front transmission mount:
Need to build th axle fist before i can start on the frame, so i cut off the drive sprocket from the Motodog:
Cleaned it up:
Flipped it around and turned down the other weld bead:
And pressed out the axle:
Then i reamed the hole:
Here`s everything that`ll be mounted on the axle:
Turned a flange for the brake disc:
All the finished axle parts:
Started by cutting the square tubing for the frame today:
Then i roughed out the front crossmember:
And bored it to size:
Then i turned the front axle bearing housing:
Welded it in:
And pressed the bearing in:
Tacked the frame:
And mocked it up:
Then i turned down the annealed output sprocket:
And bored out the new one:
Fit`s like a glove:
Looks like i ****ed up something with the frame and the final drive:
Now i like it better:
How it looks all together:
No real plans. Cruising around town and hoping there are no cops around maybe? Maybe i`ll also build a blade for it to clear snow...
Made some mounting plates for the axle bearings:
Tacked them on:
Started turning the front axle:
Located the holes for the stub shafts:
And drilled them:
Turned the first stub shaft:
It`ll looks somehow like this. Will probably shorten the stub shafts a bit.
ripperj
Cruising around town would be cool, here in the US I would end up in jail.
When I was a teen my dad and I made a trike with a BMX bike front end and a typical go cart type rear, I had a blast with that thing and it would go anywhere . I kept breaking the spokes and bending the rim on the front wheel.
Wouldn`t be too funny if i get caught by the cops here either... :Wow1:
Turned the second axle stub for the front axle today:
Tacked them on:
And mocked it up:
Then i put in a frame crossmember:
And made the rear tranny mount:
Then i made some tabs for the seat mount:
Bored out a piece of pipe:
And pressed in some brass:
Reamed it out:
And put in a grease zerk. This wil be the pivot for the seat mount:
Also made some seat mounts and tacket them on:
Starts to look like something:
ripperj
"Starting to look like something"
I'm not sure something is correct, "neat, cool, crazy, bizarre " maybe closer :)
Doesnt look safe for a 3 year old!
Sent from my Passport
Started by notching the seat mount strut yesterday:
Then i put it together:
Made some mounts for the shock:
And welded them on:
Then i noticed that the spring rate was way too low, so i had to think of something else:
Now it works great:
Also need something to tow a trailer and a tow hook. So i took a plate and drilled some holes:
Welded on a small rod eye:
And put it on:
Today my rims arrived after going up and down through the whole country for the last 1,5 weeks. The tires appeared to be in a much better shape than it looked like in the auction pics so i decided to use them:
So it was time to machine some wheel flanges. Had a piece of 6" round that i cut in half :
Welded on some short pieces of pipe to grab it in the three jaw chuck:
Turned the flanges:
And put in some centers for the bolt circle:
Then i drilled them on the drill press:
Now i could mount the flanges on the axle:
And put the wheels on. Should be a roller by tomorrow.
Started by turning the front axle stub shaft today:
This is how it`ll be mounted:
Cut up a rack and pinion steering:
Turned a tie rod extension:
Should go in somehow like this:
Turned a bearing seat for the steering column:
Pressed in the bearing:
Turned the upper part of the column:
All the pieces together:
For the steering wheel hub i cut off the end of an old vice handle:
Turned a register for the steering wheel:
And milled a snug fit square on the column:
Cut a thread for a set screw:
And welded it in:
The upper steering column completed:
And tacked in:
Aligned everthing in the lathe before welding:
Welded everything up:
Mounted the rack:
And the whole steering assembly mounted:
Only things missing for it to be a roller was the steering arm on the front axle. So i started by boring out some round stock:
Milled on some flats for the bolt:
Slit it:
And drilled the cross hole:
that`s how it goes together:
Was able to salvage a piece from the Motodog for the steering arm, just had to cut a radius:
And tacked it on:
Put down some welds to prevent it from falling apart when i remove the jack stands:
And then i just had to put the tank back on even if i didn`t want to use it. I have to say that i really like it:
Thanks. :bike_rider:
Build the clutch system today. First i mounted the pedal to some flat stock:
Cut a thread:
To mount the clutch handle:
Milled a bracket for the cable:
Tacked it on:
Finished:
Started with the brake pedal today. Had a hard time figuring out how to clamp it for milling:
Worked out better than i thought it would:
Bend up a lever:
Tapped the pedal:
This is how it should go together:
Luckily i bought it like that. It`s about 220mmx500mm and has about 678 M8 holes.
Continued working on the brake today. First i turned a pushrod:
Milled on some wrench flats:
This is how it goes together:
Bent it a little:
Perfect:
Then i turned a bushing for the gas pedal:
And brazed it on the other half of the vice handle that i used for the steering wheel hub:
WonaWarrior
