Project Microtrac
Zeep
Current exhaust route, looks like you'll have eye's and ears full of fumes! :smiley_drive:
Was like that on the Motodog too and didn`t seem to be that bad.
Thought about rerouting the exhasut a lot but couldn`t find any good solutions. Will do it for sure if i have some good ideas how to do.
Worked on the gas pedal today. First i made a mount for the cable:
Then i made a lever to go on the pedal:
Brazed it on:
This is how it goes together:
Mounted a spring to take some load of the carb and the cable:
And made a skid for it. Don`t like the idea of it catching something and going full throttle:
And mounted:
Thanks a lot.
I can`t stop thinking about building it like a ratrod or Mad Max style thing. But i just can`t come up with ideas? Do you guys have any ideas?
Made a mount for the brake cylinder today:
And mounted it:
Then i removed a broken screw:
To mount a shielding plate so the brake fluid won`t get cooked:
Then i started building the chain idler and soon realized that i messed up before. You can only shorten and put a chain back together every other link. Of course i missed that when i mounted the rear axle:
So i cut the mounting plates off:
And welded them in in the right place:
Then i pressed a bearing into the idler sprocket:
Milled a mounting block:
And tacked it on:
**** it, i try building a rat rod out of this...
First i stripped it back down:
Had a look at the scrap bin:
Lowered the upper strut:
And bend up a bonnet:
Was a bit short, so it put on another piece:
Cut the sides:
And welded them back on:
In case you where wondering why i pull watering cans out of the scrap bin:
Bend up a strip of sheetmetal today:
Cut some shapes out:
Tacked it on:
Welded it up:
And ground it down:
Then i soldered a pipe out of copper:
Thought about a cow catcher too. Not sure if it would be too much?
Don`t think i`d have any chance in that competition.
I think this thing needs a grill, so i started thinking:
Milled some slots in a piece of sheetmetal:
Bent it up:
Welded it:
And ground it smooth:
Made a hinge for the hood:
And a nice cone for the rear:
Then i cut a hole in the hood:
And put in the tank:
Brazed the heat sink on the exhaust:
And put it together:
Brazed a big hydraulic fitting in the gas tank:
Brazed on some mounts:
And made a filler cap:
All together:
Mounted a couple hood fixtures:
Put on the shifter for the second gearbox:
And made a linkage for the first one:
Put on some headlights:
And a total:
Anyone able to photoshop this with some John Deere colours? Think this`d look good, but not sure about all the copper and brass...
vertical.dan
