Project Microtrac
Made a flapper for the exhaust today:
And mounted a horn:
zetabird
Brazed a big hydraulic fitting in the gas tank:
Brazed on some mounts:
And made a filler cap:
All together:
Mounted a couple hood fixtures:
Put on the shifter for the second gearbox:
And made a linkage for the first one:
Put on some headlights:
And a total:
Anyone able to photoshop this with some John Deere colours? Think this`d look good, but not sure about all the copper and brass...
i dont know about the deere colors, it kinda looks like a medieval helmet, i think it would look good in grays and silvers to make it look battle worn
I think it`ll be a few bits of black and a lot of rust...
Located the sprocket and brake disc on the axle:
Put down a tig root pass:
And cause i don`t trust myself welding tig i ran a mig bead over it:
Sprocket is made out of some carbon steel, so i had to preheat it:
Then i faced the brake disc flange:
Put the axle together:
And put it back in:
Made a mount for the brake caliper:
Put some air pressure in it to align everything:
Finished:
Then i made a battery mount:
Put in some gussets for the trailer hitch:
Preheated the drive sprocket:
Welded it to the coupling:
And put it in some blankets to cool it down nice and slow:
Then i made a fitting for the gas tank:
And brazed it in:
Mounted the kill switch:
Made the first chain guard:
And started with the second one:
Maybe i can test drive it tomorrow.
Before i could continue on the chain guard i had to block the right exhaust outlet. So i turned a disc:
And welded it in:
The upper part of the chain guard:
Front side piece:
Didn`t have the right size tubing so i had to machine it:
Before welding it in i tacked in the rear side piece:
And welded everything together:
Took it apart and welded everything:
Every connection that didn`t have a lock nut got Loctite when putting it back together:
Finished the steering:
Made the brake line:
Flared it:
And bled it:
Then the only thing that was left was this mess:
So i mounted the charge controller:
The fuse box:
The ignition ecu:
So i didn`t have fuel lines, gas or the right connections for the battery. I was about to leave and call it a day when i thought it`d be a good idea to hook up the battery somehow and see if it turns, cause the battery isn`t new. So i rigged up this setup:
Turned right over:
Then i remembered that i stil have the old gas tank laying around and it should still have some gas in it. So i hooked it up and let the carburators get some fuel:
Then i pushed the start button again:
[video]https://youtu.be/Fzt2g5Q6Q_Y[/video]
Wired in the probably most important part of the vehicle, the kill switch:
Wired the battery in:
Ran some fuel lines:
Put some gas in:
Moved it to the other part of the shop:
And hung it to the crane to test some stuff before it`s sitting on the ground. Luckily i did that, cause the clutch didn`t work. It was engaged at all times:
So i removed it and got it working...
Then i drove around quite some time in front of the shop. Unfortunately no video cause it was dark:
Appears everything is working pretty well. Need to adjust the idle and wire the fan asap. Any ideas on that? I`m thinking on just a simple switch cause there`s no water to place a temp switch.
DanCooper
Love the video. Must have scared the neighbors to see and hear that little tiger rolling by. I think the only thing missing is a way to emit dark oily smoke form somewhere on the machine . . .
So i pulled it out of winter storage today and it fired right up. This is how i like it. :grinpimp:
End of last year it started making funny noises out of the gearbox. Today it went with a bang and didn`t move at all. Well, didn`t have to look for long to see what`s wrong:
Removed the gearbox. It already had some cracks and was repaired when i got it. Thought i`d give it a try. At least it held up quite a while:
Gears and bearings look great so i just have to repair (read: make new one) this mess:
Also going to fit some new wheels up front:
Probably need to build a new front axle with some kind of suspension cause the wheels won`t compress any more...
Thanks.
First i drilled the mounting holes:
Transfer punched the centers:
Flew in the four jaw chuck:
Dialed it in:
And finished the first side:
doug720
I wish you were my neighbor!
I consider myself a good fabricator, and make many parts. But, you are one hell of fabricator, machinist, engineer, and all around dreamer!
Great work.
WonaWarrior
