Quadrotrac
Changed my plans quite a bit today. First i wanted to finish the rear car first, but i talked to a buddy today who is a car body and sheetmetal guy. He said he has a week off work now and doesn`t know what to do. I said great i got some work for you. So he started pulling out the windows of the cab:
While i put the rear car roughly together:
Then we turned it around and rolled it out on it`s own wheels for the first time:
Need to clean that mess when the cab is inside the shop:
He started working on the door first, here`s the marking for the cut:
We both were curious what`s behind this ghetto fab panel. Looks like they just put it over the ripped apart door lock:
While he was working on the door i started getting the chassis table level and building the frame:
Started building the frame:
Got rid of all the axle accessories:
Shortened it:
And put it in the frame:
Then we put up the "may tree":
After that i had a couple comrades from the fire department help me to bring the cab in the shop :
Had to build the driveshaft first, to set the axle position:
Also was able to open up the roof door:
And removed the guard from the window, so there`s no jail feeling any more:
Sure, that`s on my "want to build" list... :drool:
The cab is to tall for the crane, so i used a ratchet strap:
Cut of the front part:
Placed it on the frame:
Changed the frame a bit for the front end loader:
Tacked the cab on:
Started rebuilding the front part:
Finished:
Then i cut off everything that i`m going to rebuild:
chilliwak
Not much :Wow1:left of thew original cab Steinez. But I guess thats what Redneck Engineering is all about!:ylsmoke:
Well, that would`ve been to easy, right? :ylsmoke:
Ok guys, need some help with the winch:
I`ll be getting a hydro motor, that will be used as a direct drive on the drum. This gives me about 4000lbs pulling force at 50 yd/min. Drum will be 2 3/8" diameter. Do you think that .158 wall is strong enought? Also, how much winch line should i use? I`m thinking about 55yd dynema. Anyone knows how wide the drum needs to be to accomodate that?
Got the seat today:
Looks like the perfect spot for it:
But then the serpentine belt blew up again on that pos audi, need to fix that:
:mad::mad::ar15:
chilliwak
Serpintine blow up again? Are you in war?:truck::ar15::shakin::Astrologist::jumping::imagesCADZQMBJ::pROFSheriffHL::gunt::clapsmile
Didn`t get much done lately, my grandmother passed away a couple days ago. But i could get a few minutes for the shop. What i did? Of course, i cut off another part of the cab:
Didn`t like it, so i cut off more:
Then i finally started putting on new stuff :
chilliwak
Sorry to hear about your grandmother passing away Steinez but happy to see the progress on your rig!:)
Thanks Allan. :smiley_drive:
Started by cutting more stuff off the cab today:
This will be the new door opening:
Then i started building the rear of the cab:
Also got a new vice today:
No, it`s perfect as it is. Works out like planned. Didn`t plan to cut off that much thought...
Made the seat mount first today:
And finished the rear part of the cab:
Also bough myself a plasma cutter. Not the best but better than nothing...
AZXPLOR
