Quadrotrac
chilliwak
Looking good :Wow1:Steinez. You must be getting close to test drive time soon.. But remember to put a `Redneck Engineering ´ logo on the vehicle!:ylsmoke:
chilliwak
Steinez I have a donor truck available to build this...
The only problem I can see is that it is only possible to make a track drive to the rear, as opposed to the front drive in the origianal German half track.
Can you see any problems with this?:Wow1:
Nope, should work just fine.
Got the hydraulic drive for the winch today:
This is the winch i`ll get to use as a core:
This is the hydraulic drive i`m going to use:
"Just" need to look how the winch is geared and how i can mate them together.
Started cutting some steel today:
Then i started mocking up the front hydraulics:
Cleaned the ram up a bit:
And put it on:
Looks like this will be fun until i get it how i want it.
chilliwak
Looking good Steinez. I cant wait to see the finished product. Here is another teaser pic for you to get you motivated on another project...
Ya got to love it....:Wow1:
Sorry to take focus away from your fine project...
Had to use steel instead of wood for mock up:
Then i remembered i have some hydraulic rod ends laying around that i could use:
Few hours later i got it where it`s supposed to be. All the way down:
All the way up:
Did the math. Looks like i need a valve to get the pressure down:
Then i started with the ram mount:
The saw also finished cutting today:
chilliwak
Nothing like the pic of a Nazi half track in front of a bombed out church for motivation!
Actually both me and Steinbruchsoldat are huge fans of vintage WW2 vehicles. He helped me develop the camoflague paint for my rig as shown here...
So when I post a pic of a....
Kfz 251 from WW" it is actually motivation as we are going to build a replica of this vehicle....:coffee:
chilliwak
Pretty solid looking mount that you built Steinez. Is it offset to one side or is it just an optical illusion from the pic? I can guess that this will be the ram and mounting for the dumper. Are you going to have any other options/accesories for the vehicle? Cheers, Chilli...:)
Yes, it`s offset to the driver side. There will be the upper link mount in the middle and the ram offset to the left. I`m building this to commercial specs, so i can use almost every agricultural/forestral attachment. Also going to build a front end loader for it.
Didn`t get the winch today, so i finished the most time consuming shackle mount ever:
Got the donor winch today:
Took it apart, looked like it wasn`t sealed right:
Put it in the parts washer real quick and it looked a lot better:
Did some math, doesn`t look bad:
Still got a good idea about the planetary drive, need to look into that tomorrow...
Wainiha
Holy smokes. Look at at your math. Haha. Anyone else here as good as Stein?
You live up to that stereotype of German engineers being the best!
Hope I'm not offending you with the stereotype comment....
Thanks . No problems with stereotypes as long as its not that Nazi crap...
Got the window washer:
Played a bit around with the winch:
Now i just need to design some minor parts and calculate the right drum diameter then i can start building it.
AZXPLOR
