Quadrotrac
Slowly gathering all the parts for the new wiring:
Will finish my last exam on saturday then i`ll have some time to work on this thing again.
Today was an awesome day. First i passed the last exam, so i`m a service engineer now. Then i got a call that everything should work out with my new shop.
But i got something done too. First i mounted the side facing working lights:
Also the rear strobes:
The horn:
And the compressor for it:
Then i turned some M19x1 inside threads:
So i can screw in this push button switch:
Turned some grooves:
Flipped it around and did the same thing again, just put different grooves in:
Cut it off and drilled a hole for the wires:
First one is the steering lever with horn switch:
Second one the wiper lever with washer switch:
Finished the safety lock for the steering lever:
Then i cut the old instrument cluster:
Thats what i`m going to use:
Soldered some wiring in:
Tested it:
Then i started cutting the new dash:
Congratulations on passing the exam!
Dude, that thing is going to look like the sun at night!
Sent from my Passport using Tap
This is coming along man, looks great. I love the handles...
Congrats on your final exam and your new certification, feels good to complete something like that. I remember finishing my Red Seal Journeyman Program years ago, felt like a big accomplishment.
It`s not sure yet if everything works out. But if, it`d be great. It`s about 600m², got a 3ton crane in it and like 150ton worth of machinery. Some really big ones like a vertical lathe, a 200t press, just everything really big.
Mounted two 12V outlets and the wiper switch today:
Couldn`f find a dome light that i`d like, so i thought i`ll build my own. Squared up a scrap piece of aluminium:
Milled some features in it:
Drilled some holes and put a few threads in:
Finished except of the clear cover:
Good work on the rig Steinez, as usual. Can you post any pics of the new shop? 600 square meters of room. WoW:Wow1: You must be thing of going into production!:)
Removed the seat today:
Then i brought out my hydraulic hole punch:
And put in some grommets for the shifter cables :
Then i made the air intake for the heater:
Need to relocate the hot/cold lever so i started building a linkage:
Milled down the backside of the mount:
Used my new scribe for the first time, it`s really awesome:
Milled a rectangle in:
Tacked it in:
And made a linkage for it:
Also bend up another tube...
empireoverlandza
